Results 1 to 8 of 8
    Nov 2012
    Hmm Zoning,By-Pass, and Variable Speed
    Hello, looking for some thoughts regarding using VVT style zoning on a variable speed furnace/air handler. Since the motor is load dependent (IE adjusts RPM based on static/resistance to ensure constant volume) how will it react to a bypass damper? I have done a lot of zoning with standard equipment with no issues but these ECM motors have me on the fence regarding trying it out (gets costly after its all installed and don't work). Ive Googled the snot out of it and get recommendations each way. EWC doesn't seem to have a problem with it. Thoughts, experiences?
    Thanks,
    Atlanta GA area
    Good question... and there is lots of discussion about zoning at H-talk... however: This is a professional site which allows non-pro's to visit.
    Reading your post, it appears you have some experience... SO: You need to get your post count up to 15, then apply for Pro status. The forum mgt does not allow us to offer tech stuff on open forums. Behind the PRO door, there is a wealth of knowledge; technical, educational and business.
    Search around the site and find a link to apply for PRO status... apply, wait a week or so (the folks who check you are volunteers). Pro status is well worth the effort to join.
    GA-HVAC-Tech
    Nov 2012
    Thanks for the heads up, yes I have been dabbling in HVAC for a few years (25+, need my abacus to calculate it). As I have just joined I'm still learning the rules. I will take the next steps as advised.
    Nov 2012
    #3, ok I know, bad toad!
    Dec 2010
    Quote Originally Posted by Precise View Post
    Thanks,
    Look at the website regarding Arzel Zoning products. I've been promoting (and selling)zoning for approx. 20 years.
    Arzel is the first, that I am aware of, that developed a modulating by-pass to solve that "hunting" problem of a barometric by-pass.
    Atlanta GA area
    Quote Originally Posted by George2 View Post
    Not sure about the first... however EWC has an electronic bypass valve. A bit pricy, however it works nicely.
    GA-HVAC-Tech
    Nov 2012
    Yeah, Ive installed a lot of EWC. Good product, even better support.
    Atlanta GA area
    I like EWC products... and I talk to Paul in tech support regularly... cool dude. He got through 'Sandy' with not too much damage... the co was closed for a few days though.
    What I like about EWC is the products are ROCK SOLID! And I love the damper motors... nice to work with and the pilot lights are cool! One only has to glance at each damper to know it is working... unlike some others where one does not know what it is doing.
    GA-HVAC-Tech
