Results 1 to 7 of 7
    Jul 2012
    Question about by-pass humidifier and furnace air filter
    With my bypass humidifier dumping the humid air into the return airflow, which is then filtered by a Merv 16 air filter ... wouldn't all the humidity be caught by the filter?
    I'm having a hard time keeping the humidity at 30% RH with the winter now here and it seems my humidifier is running all the time. Is all the humid air being caught by the airfilter?
    Oct 2010
    No its not being caught by the filter but it sounds like it needs to be serviced.
    DC Metro Area (MD)
    No -- common configuration for bypass humidifiers. When is the last time you checked/replaced the water panel in the humidifier?
    Virginia
    is the summer/ winter door in winter mode and the water turned on
    Go Trump
    Jul 2012
    Water pad is new, water is turned on and flowing (connected to hot) and winter mode is turned on. It is connected to an SLP98V so I'm thinking the low CFM and heat that is constantly runs at is not enough CFM to distribute the humid air?
    Madison, WI/Cape Coral, FL
    i
    Quote Originally Posted by tuffcalc View Post
    Increasing the air flow through your humidifier with a 6" duct fan will increase the evaporation rate. Larger shorter duct and high speed on funace fan also increases evaporation rate. At 70F, 30%RH, your inside dew point is 37^F. Whats your outside dew point or location? What is the temp of the water going into the humidifier? Check with fingers. Neutral indicates 98^F. 35-40%RH is about as high as you should go to avoid condensation on windows and other cold surfaces.
    Regards TB
    Full model number of the humidifier and the furnace would help us.
    Sealing your homes infiltration would help it retain more of the humidity.
