Page 3 of 6 FirstFirst 123456 LastLast
Results 27 to 39 of 73
  1. #27
    Oct 2002
    Plano, TX
    Weedeater fight with CU control wires.
    Happens all the time.
    But, only when there is a call for cool.
  2. #28
    Quote Originally Posted by ControlsInMT View Post
    Wait...pull the fuse before it pops, change furnace. Problem solved!
    ROFL.
  3. #29
    Nov 2012
    Tahlequah OK
    If I was there I might tell you the problem. You are supposed to be a tech so figure it out. Do you carry a journeyman license? Why did you change the blower motor? Didn't understand your reason. I kinda lost signal. Does this happen in cooling and heating mode?
  4. #30
    Houston,Tx.
    Quote Originally Posted by welling service View Post
    Quote Originally Posted by Bmurph1409 View Post
    I only changed blower because home owner asked.
    Maybe this will help with your question.
  5. #31
    Oct 2011
    Chicagoland Area
    That a common request with you resi guys? "While you're down there changing the gas valve, would you mind charging me more money and changing out the blower motor?"
  6. #32
    Jul 2010
    Eastern Kentucky
    short in condensing unit??? Nahhhh. probably bad TXV in air handler
  7. #33
    NE wisconsin
    Thats called preventive replacement, if you put a new blower motor in every year its a lot less likely to fail in the middle of the night.
  8. #34
    May 2012
    Upper Michigan
    I think I smell a youngwiseman thread here, bump!
  9. #35
    Mar 2009
    Mid-Mo
    Let the entertainment begin!!!
  10. #36
    Tallahassee, FL
    I doubt we will ever hear from bmurph again.! Poor guy!
  11. #37
    Nov 2012
    Tahlequah OK
    Mr. Bill look at the words extremely load in one of bmurph's post and explain to me what they mean.
  12. #38
    load=loud
  13. #39
    Southeastern Pa
    I've been working on a ducane gas furnace and have replace almost every part but the 5 amp fuse keeps blowing every 6 hrs or so. I even changed the thermostat wire the t-stat itself, the control board, the gas valve and even, the blower and it still blows could it be the condensing unit
    I smell DIY.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
