Page 3 of 6 FirstFirst 123456 LastLast
Results 27 to 39 of 73
  1. #27
    Oct 2002
    Weedeater fight with CU control wires.
    Happens all the time.
    But, only when there is a call for cool.
  2. #28
    Lancaster PA
    Quote Originally Posted by ControlsInMT View Post
    Wait...pull the fuse before it pops, change furnace. Problem solved!
    ROFL.
  3. #29
    Nov 2012
    Tahlequah OK
    If I was there I might tell you the problem. You are supposed to be a tech so figure it out. Do you carry a journeyman license? Why did you change the blower motor? Didn't understand your reason. I kinda lost signal. Does this happen in cooling and heating mode?
  4. #30
    Houston,Tx.
    Quote Originally Posted by welling service View Post
    Quote Originally Posted by Bmurph1409 View Post
    I only changed blower because home owner asked.
    Maybe this will help with your question.
    "The critic is a prisoner to his own experiences and perspectives, erroneously believing his limited experiences are the sum of all truth".
  5. #31
    Oct 2011
    Chicagoland Area
    That a common request with you resi guys? "While you're down there changing the gas valve, would you mind charging me more money and changing out the blower motor?"
    Local 597 Service Fitter
    Metal Trade Journeyman
    PAY ME NOW OR PAY ME LATER
    It was working when I left...
    WWFD
  6. #32
    Jul 2010
    Eastern Kentucky
    short in condensing unit??? Nahhhh. probably bad TXV in air handler
  7. #33
    NE wisconsin
    Thats called preventive replacement, if you put a new blower motor in every year its a lot less likely to fail in the middle of the night.
  8. #34
    May 2012
    Upper Michigan
    I think I smell a youngwiseman thread here, bump!
  9. #35
    Mar 2009
    Mid-Mo
    Let the entertainment begin!!!
  10. #36
    Tallahassee, FL
    I doubt we will ever hear from bmurph again.! Poor guy!
  11. #37
    Nov 2012
    Tahlequah OK
    Mr. Bill look at the words extremely load in one of bmurph's post and explain to me what they mean.
  12. #38
  13. #39
    Southeastern Pa
    I've been working on a ducane gas furnace and have replace almost every part but the 5 amp fuse keeps blowing every 6 hrs or so. I even changed the thermostat wire the t-stat itself, the control board, the gas valve and even, the blower and it still blows could it be the condensing unit
    I smell DIY.
