Page 2 of 6 FirstFirst 123456 LastLast
Results 14 to 26 of 73
    Oct 2011
    Indiana
    3 amp fuse in a 5 amp slot?
    Nov 2009
    Kansas City
    If I was you I would have done the smart thing... Called a service technician
    Anderson SC
    were not allowed to give DIY advise to non pro members. If you are a tech, get your post count up and apply for pro membership. You will get all the help you need then, but until then you will not get any useable advice. What is a "Ducane Tech" a gas furnace is a gas furnace to a tech, they all work pretty much the same.
    how many places do you have to post the same question?
    Might of ended up saving $ by calling a professional ..
    Sent from my SGH-T999 using Tapatalk 2
    Sep 2012
    Central Florida
    This thread is an eye opener for me. Working in a factory run testing units, they wont let me just change parts out if fuses are blowing. They ***** at me if I blow a second fuse without finding the problem, let alone just changing boards, blowers and thermostats. Is this how stuff is actually done in the field?
    Lancaster PA
    Merge your 3 threads on this into one.
    Please don't make duplicate threads, thank you.
    Oct 2002
    I've visit this , in other posts, before.
    Start troubleshooting this systematically. Fuse all loads, including Common. Which fuse continues to blow? Then Trace the circuit flow through the bad fuse.
    Remember, stat wire runs, without a blue(common) conductor, will not blow fuse but will energize a circuit if it is shorted. Unless it is going to a ground and transformer is also anchored to ground.
    6 hours to blow may be overnheated fuse connection. Look for weak, heated fuse connection. This is obvious,Did you use an amp meter?
    Oct 2011
    Chicagoland Area
    Quote Originally Posted by Bmurph1409 View Post
    Wow what great help not really. How about someone who actually knows about this because even ducane tech couldn't figure it out.
    and none of us can figure it out either. We can only lead you in the right direction. Check your low voltage conductors and loads individualy. Please remember, You are not entitled to my knowledge nor that of anyone elses on this board. How about being a littless rude.
    Local 597 Service Fitter
    Metal Trade Journeyman
    PAY ME NOW OR PAY ME LATER
    It was working when I left...
    WWFD
    I've been working on a ducane gas furnace and have replace almost every part but the 5 amp fuse keeps blowing every 6 hrs or so. I even changed the thermostat wire the t-stat itself, the control board, the gas valve and even, the blower and it still blows could it be the condensing unit
    You have a time line here what sequence of events takes place every 6 hours? Remember the five basics of trouble shooting
    1 Talk to the operator
    2 Accomplish a visual inspection
    (Safety , Safety , safety )
    3Attempt to operate the equipment
    Important note : If there is a remote chance of possible damage to personnel or equipment SKIP THIS STEP.
    4 Voltage checks
    check supply voltage first , then control voltage
    5 Use the documentation (i.e. ladder drawing) and the appopriate test equipment to logically troubleshoot the circuit and isolate the problem.
    If you have replaced all the parts its possible something was rewired incorrectly.
    Above all remember be safe if you do not have a good feel for you level of competency. Do get the correct help and learn from the pro.
    Good luck
    Feb 2007
    Helena, Montana
    Wait...pull the fuse before it pops, change furnace. Problem solved!
    "Fortunately, I keep my feathers numbered for just such an emergency." Foghorn Leghorn
    Houston,Tx.
    what does being epa certified have to do with the price of beans in Africa?
    Because there the EPA they have to monitor the beans sold there, because they only allow so many farts in one day.
    “I am glad that I paid so little attention to good advice; had I abided by it I might have been saved from some of my most valuable mistakes.” - Edna St. Vincent Millay
    The critic is a prisoner to his own experiences and perspectives, erroneously believing his limited experiences are the sum of all truth.
    No Guns…No Freedom…Know Guns…Know Freedom.
    Jul 2012
    Richland, WA
    Disconnect the wires running to the condensing unit for low voltage and that will tell you it there is a problem at the condensing unit
