Results 14 to 17 of 17
12-10-2012, 04:46 AM #14
New Guest
- Nov 2012
- 4
So we decided to go with a Trane 80% unit. Were debating wether we go with a XL80 or a XV80? Is there variable speed worth the money or necessary for the amount were going to use it?
Also I have had 4 estimates and 3 of them are different BTU pumps (40k, 50k and 60k) shouldn't they all becoming up with the same calculation for BTUs?
12-10-2012, 09:40 AM #15
You must mean they have a wall furnace in the living room. In your area you have 2 choices . You can cut in a attic furnace or depending on the area and codes you can do a roof top. I would forgo the 90% and go with a 80% VS 2 stage system. I would install a Honeywell wireless T stat so your mom and Dad can control temps in any area of the house with the remote .They can also view outside temps and hum levels from same easy to use stat. I assume you have a attic and it is old school construction so more then likely the attic access hatch will need to be enlarged. You may be right about the AC, however check the temps last year I think you have been in the 90's more then a few days for the past couple of years . Take some of the savings from 90 + % and possibly apply it to AC. We did 2 jobs in that area for friends of people we did jobs in my area and they both went with AC. Rheem is good but the install trumps the brand in most cases .
12-10-2012, 09:46 AM #16
12-10-2012, 08:33 PM #17
Professional Member*
- Nov 2004
- SW FL
- 5,270
Designer Dan
