Results 14 to 24 of 24
Thread: Hill Phoenix
    Jan 2010
    Neither.
    It's just, I had recent bad experience with Hill is all.
    I like Zero Zone stuff.
    That Zero Zone stuff is quality for sure. The last one I serviced was built like a tank.
    Almost 100% of the new equipment we're installing is H/P or Barker. I've set up quite a few of these EEVs recently.
    Suction temperatures have been moving upwards over the past 10 years or so.
    Meat cases used to want to run at 12 degrees SST. Now, I'm setting them at 18-20SST and getting the same or better product holding times. Better designs.
    Newer case, I'd start at 18 SST or so, and see where it goes from there.
    What I'd do is measure the SH. If it isn't high then I'd either start by replacing the transducer, then the temp sensor OR, I'd do as blackmira suggested and break out the Q kit, IF and ONLY IF, the case is over 12 months old.
    Our company got burned on one where a guy did that. H/P rep walked in, looked at the case and said "You modified it, warranty void" Customer made us put an EEV back in the case. Almost all of us carry transducers and sensors. One guy in each region carries a laptop and a dongle.
    Lately, I'm tending to agree with Phase Loss. Hill/Phoenix sure ain't all that excellent on the quality side of things. Too many little details that aren't right.
    Meh..... I helped out on a startup in a ZZ store.
    Neat stuff, smart factory guy, but no more special than anything else I've seen.
    Jan 2013
    Northern CA
    Neither.
    What happened at Hill Phoenix? And zero zone, oh boy that's some junk...
    California
    Quote Originally Posted by Icanfixitall View Post
    Have you worked on their stuff???
    Jun 2001
    Michigan
    I wish the device and assembly also had DA.
    florida
    SMS sucks.
    Educational forums are open.
    May 2008
    Massachusetts
    Sorry to bring up an old post.
    Anyone know where I could buy one of these over prices USB Dongles other than Hill Phoenix?
    Dec 2013
    Nashville TN Metro Area
    But while were on this subject, here is a post from a couple years ago showing the use of some technology to troubleshoot the issues you are describing: http://www.midtennrses.net/2014/08/u...-troubleshoot/
    Our company supplied us with one of these dongles from HP and I am not sure where you can purchase one other than from them. Getting it all walking and talking can also test your computer skills; ports, software, drivers, etc.
    Sporlan should take some credit for the flaws with these control systems. We have a company policy that if it doesn't take a sensor or transducer to get it going, then cut it out and go conventional. Always remember that you will have to connect an external equalizer line to the setup. You can probably use the port that is left from where the transducer was connected.
    JaaGeeGee
    Can you still GET transducers and sensors for the older systems?
    Sure would be nice to be able to find a supply. Nobody around here that I've spoken to seems to be able to find them.
    Dec 2006
    In a Mess
    pretty sure the older one also uses the 150 # transducer, local sporlan shop can get it for you Part # 952572
    Dongle and control are proprietary to Hillpxh (was built by sporlan though)
    you can easily convert SMS to a KELVIN II controller using existing valve sensor and transducer, easy if superheat only, i think you should use the chiller one or the subcooler one if you also need temp control, just make sure what your SMS is doing to decide.
    Mike
    Sig removed by mod. G-Rated site
