Results 1 to 13 of 17
    Jun 2009
    Albuquerque NM
    VisionPro IAQ thermostat - strange behavoir at midnight?
    I have a VisionPro IAQ thermostat and I've noticed this strange behavior twice in the last few days. I am running 3 CPH on heat. Right around midnight, it did 3 very short runs with very little OFF time between runs, during a period of about a half hour, and then resumed normal cycling at about 3 CPH. Load is about 50% at this time, so normally runs are about 10 minutes ON and 10 minutes OFF.
    11:56pm to 12:04am (8 minutes ON)
    1 minute OFF
    12:05am to 12:12am (7 minutes)
    3 minutes OFF
    12:15am to 12:23am (8 minutes)
    After this, it ran several cycles of about about 10 minutes OFF and 10 minutes ON.
    Is this strange or what?
    Keokuk, IA
    Did you feed it after midnight?
    Lancaster PA
    Thats strange. Did you have any power outages during the day when this happened.
    Athens, Ohio
    Have you checked the programming? Could there be any setback/setup changes within that 1/2 hour?
    Keokuk, IA
    Quote Originally Posted by kdean1 View Post
    That was my thought. There's a couple of periods mashed in there.
    Athens, Ohio
    If two of us think so, then it must be right.
    Jun 2009
    Albuquerque NM
    Not that I know of. The first time I thought it was just a one-time thing, or maybe I imagined it. Then it happened again just like the first time.
    I have all periods programmed for th same temps, and the "sleep" period starts at 10PM anyway.
    Athens, Ohio
    Quote Originally Posted by garya505 View Post
    Maybe you have already done so, but I'd still check all 7 days on the program.
    May 2008
    Central Fla.
    Do you have a back up generator? If so it maybe going through it's testing at that time and causing it to short cycle going into and coming out the testing due to loss of power.
    Jun 2009
    Albuquerque NM
    No back up generator.
    I have a suspicion that this is caused by the weather here. We usually have a large day-to-night temperature difference. Since I have been watching the cycling behavior, I have noticed what appears to be some short cycling well before midnight, which seems to correct itself after a while. Could it be that the PID algorithm does not handle the large drop in temperature very well, and takes some time to adapt?
    Jun 2009
    Albuquerque NM
    OK, there it goes again. 11PM
    10 min ON
    1 min OFF
    9 min ON
    1 min OFF
    3 min ON
    11 min OFF
    10 min ON
    15 min OFF
    Got any ideas?
    Lancaster PA
    Looks like its trying to do 4 CPH. Set CPH to 2 and see if it still does strange cycles.
    Could be a faulty stat.
    Jun 2009
    Albuquerque NM
    Yes, I was wondering about that, but it seems to work fine most of the time.
    Actually, the OFF times I listed above are all shorter than stated, by 90 seconds, because the furnace runs the blower for 90s after the call for heat ends.
