    Nov 2012
    Upstate New York
    Oil In refrigerant lines
    I just removed a residential 2.5 Tn compressor and air handler. I got over a pint of oil out of the refrigerant lines after I recovered the old R-22. The AH is in the basement with about 30 ft of line set. The AC was shutdown for the winter. I don't ever remember getting this much oil. This normal ??? or was the compressor failing ????
    Wildomar Ca
    Angry Oil in refrigant l
    Quote Originally Posted by JimBE323 View Post
    This could be caused by a dirty evap coil or running the a/ c at low temps.
    This causes inseffient oil return to the copressor.
    I wish this site had spell check.lol
    Nov 2012
    Upstate New York
    Both the evap coil and the heat coil were filthy .... no access to the heat coil on this vertical AH. Customer tells me no service on the unit since it was installed almost 10 years ago. Thanks for the reply
Quality Home Comfort Awards
