Results 1 to 8 of 8
    Jul 2005
    Phoenix, AZ
    Ice Machine Tool List
    What is a good tool list for servicing ice machines in restaurants, service merchandisers and convience stores
    Sent from my DROID RAZR using Tapatalk 2
    Jul 2011
    Lehigh Valley, PA
    By servicing, do you mean "cleaning" an ice machine?
    Jul 2005
    Phoenix, AZ
    I mean breaking down augers and cleaning and servicing all types of ice machines. What are the tools you would recommend getting?
    Jul 2011
    Lehigh Valley, PA
    I'm lost. No idea what you mean by an auger.
    Cleaning solution, bucket, brushes & garden hose and/or good spray bottle.
    I use brushes I bought at supply house typically used for boiler cleaning. Obviously, my brushes are dedicated to ice machines. But the units I have been cleaning are extremely moldy, I have to dismantle, clean & reassemble.
    Jul 2005
    Phoenix, AZ
    The spinning blades on Scotsman flakers with bearings and water seals.
    Jul 2011
    Lehigh Valley, PA
    I only do cubers. Never worked on a flaker.
    Colorado
    There is not much you can do to service a flaker except for adding the recommended amount of ice machine cleaner, cleaning the bin and chute. Anything else is big $$ for labor, and often the customer will just get a new machine. I believe the scotsman manual has a list of what tools are needed to break apart a flaker machine. The best tool I ever had for ice machines is a good screw holding screwdriver, and that Milwaukee right angle driver that they sell at Home Depot. There is not a lot of room for putting the screws back in when you disassemble for cleaning and repair.
    Colorado
    Almost forgot -
    The charge on the smaller machines is critical, so get some short short gauges with a valve. Sometimes when you put a hose on a machine to check it, the charge gets off and it never acts the same until you recover and weigh in again.
