Results 1 to 13 of 17
    Nov 2012
    retro lennox pulse with new ecm motor for continuous operation
    My furnace is in great condition. I enjoy the comfort level with the continuous fan. However, expensive to run my current furnace with the continuous fan due to the cost. Draws 6.3 amps and costs approximately $950 a year.
    Salesmen state that with a new furnace with an ECM motor only costs what a 100 watt light bulb would be for a year.
    Is it possible to update my current furnace with a more efficient motor?
    in a house, Appomattox, Va.
    You could have an X13 (ECM)motor put in. they're made as a drop in replacement for the psc you have now.
    Col 3:23
    Oct 2010
    Emerson sells a motor called evergreen that is more efficient replacent motor
    Tallahassee, FL
    Something to consider - with the reduced power consumption comes with reduced air flow.
    Your motor probably runs at 60-50% of full speed (maybe more).
    The ecm retro or new furnace will be more like 30%.
    Yes they are more efficient than your motor running at 30%. I doubt it will pay for itself quickly though.
    burlington county n.j.
    Quote Originally Posted by SBKold View Post
    Pulse furnace would be running at air conditioning speed when fan is in on position.
    creative use of relays could make the old motor or one of the new evergreen motors run at a reduced speed.
    Should be fine IF you can find some way of mounting one in a pulse. Smaller one maybe, but if it has the BIG motor, may be hard to get a mount in there. 28F01 or whatever that monster with the 40 mfd cap is!
    Virginia
    might be better off putting that money toward a new furnace with a ECM motor in it
    Go Trump
    Nov 2012
    Quote Originally Posted by catmanacman View Post
    Have a 24 year old Lennox Pulse Furnace. Thought I had a problem with my furnace, so I began the estimate process (5). However, it passed the heater exchange pressure test. Now I'm unsure what I should do. Any idea how much more life I will get out of my current furnace or should I purchase a new one now? Was very impressed with the new furnaces that have 2 Stage ECM motors. Planning on staying at my current location for approximately 10 more years.
    Oct 2010
    Quote Originally Posted by metal center View Post
    It's probably gonna cost a bit more to replace in an emergency situation than in a proactive situation, with that said most pulses I've changed out have been in the 25+ year range and most of those were only changed due to the air conditioning breaking and changing the furnace out to match the new ac.
    Aug 2001
    Pavilion, NY
    My only real concern is part availability for the pulse units. Of course the motor, relays, and fan/limit are universal, the inducer, flappers, ignition board and some other parts are OEM. I had a unit last year that needed a new plastic air flapper housing and I was told it was unavailable. My understanding is that as the parts are deplete they will not be available. With that said,,,Lennox is not supporting the furnace anymore and I would hang into it as is or replace the unit proactively if you can swing it. They are pretty simple units with a descent track record. If you have a relationship with a company that is failure with the unit you may be ok. Just my $.02
    Jul 2010
    nebraska
    In our area most pulses didn't last 25 years before the heat exchanger failed pressure test. Doubt yours has much life left in it. Don't retrofit an epensive motor into that furnace,it will be wasted dollars.
    Oct 2010
    I'm in the south where the furnace doesn't run much of the year so they last a lot longer than in a colder climate.
    Apr 2012
    winnipeg
    can not get most parts for pulse furnaces anymore in my area......seems a poor idea to dump money into a pulse...unless you have a source for parts.....
