Page 1 of 5 12345 LastLast
Results 1 to 13 of 65
    Nov 2012
    Dublin, CA
    Best sheetmetal cutting snips
    I am looking for the best sheetmetal cutting snips. I do install in addition to service, and I make my own plenums in the field. Not to mention all the duct modification I do in the field.
    None of my metal cutting tools seem to survive long. So any recommendations would be appreciated. Thank you.
    Calgary, Alberta
    Wiss. The only way to go.
  3. Dislikes chrisevansac disliked this post
  4. #3
    Apr 2012
    winnipeg
    yep... new pair every week.... ..
  5. #4
    Aug 2011
    Fort Mcmurray,Ab
    Wiss are definitely the standard, although I picked up some Milwaukee snips to try in the shop and they seem pretty good.
  6. #5
    I tried many different brands when I did sheetmetal work, and I found the Malco AVs and Max2000s were the best anywhere. The AVs were nice because the offsets were very low profile and they had a smooth operation. The Max2000s stayed very sharp, and the larger grips allowed you to cut heavy gauge metal. They had a longer cutting edge = more cuts with fewer strokes = less hand fatigue.
    I never carried anything but a right and left offset and a pair of bulldogs for cutting slips and drives. I was doing large commercial sheetmetal installs, and I could get about 1-2 years out of my snips.
  7. Dislikes chrisevansac disliked this post
  8. #6
    NE wisconsin
    When I was doing a lot of duct work new construction and replacement installs I would get about 3 months out of Irwin right offsets, though comfortable and worked good just didn't last. I got a pair of Lennox right offsets and won't get anything else ever again. Get about 12 to 15 months out of a pair. It helps a lot to only cut tin with your snips and get a pair of bulldogs for cutting the seems, slips and drives.
  9. #7
    Aug 2008
    Eagle (Boise), Idaho
    1st of let me say I do not do install and rarely use snips.
    However I do have a set for the few times a year I might need them.
    They are just cheap ace hardware brand, but they just cut right
    Through the sheet metal no issue. I don't foresee any complaints if
    I did have to use them daily though.
    Tell Obama he can keep the change
  10. #8
    Nov 2012
    Vancouver BC
    I worked as an Aircraft Maintenance Engineer for 7 years, doing quite a bit of sheet metal in that time. I'm now a first year HVAC/R apprentice.
    In my opinion, having used many different types, I found that for overall quality and Longevity, nothing outperformed Wiss
  11. #9
    Jun 2010
    Hands down midwest. They beat the hell out of wiss and I think all malco are are midwest snips with malco name on it.
  12. #10
    Dec 2008
    Buffalo NY
    Midwest are the best. Most comfortable to use.
    Join http://scopeny.org/ Shooter’s Committee on Political Education
    The world is full of sheep,try not to join the flock.
    Support the Skilled Trades, Don't DIY
  13. #11
    Jul 2012
    Near Chicago Il.
    +1 for Midwest.
    They were even better when they were sold under the Craftsman name and had the lifetime warranty
  14. #12
    I used Midwest for a while and Malco for a while, then I got a pair of Lennox rights and left and will never go back to any other snips they are the best hands down IMO. For straight cutting I use Malco 12s
  15. #13
    Atlanta GA area
    Quote Originally Posted by OnlyOneKeano View Post
    I did A&P for a while back in the late 1970's... seemed the only real $$$ was graveyard at the airlines... something I did not like much.
    I used to buy Wiss at HD... then tried Malco and use them. Have not tried Midwest yet.
    One thing for sure; one gets a better price on tools online now-a-days. I tend to buy a bundle of stuff every few mos... rather than nickel and dime... usually get free shipping and sometimes a volume discount.
    Ga-HVAC-tech
