Results 1 to 13 of 14
    Nov 2012
    NOISE IN AIR HANDLER WHEN COLD
    Good morning,
    I have an American Standard Heat Pump unit that was installed in 2001 (model #twe049e13fb0). When the weather is cold and the unit starts up in the AM there is a load moaning noise coming out of unit(inside unit).The colder it is the loader it gets, to the point you can here it through the whole house. There is no noise when its summer and you use the A/C. Unfortunately this only started after we had to have compressor changed. The tech that did job is very reputable but is struggling trying to fix our problem. This has been going on for sometime because in So. Ga. you use A/C more than heat so it just drags on. The unit when installed oringinally had one of those heat recovering systems on it and he thought that might have some effect on it but have shut off water to system and disconnected pump on it so its basically no working. One other thing about noise is that has the sound of some type of turbine whine, a moaning whine. Sorry about odd description of noise only way to describe it.
    Thanks for looking any suggestions would be greatly appreciated!
    SZ
    If you can record the noise and post it, it would help us.
    Nov 2012
    Thanx for quick reply
    Will do and post when taped
    SZ
    Tallahassee, FL
    My own unit (totally different brand) has somewhat of a similar problem.
    I do hear what almost sounds like ringing from the vent in my bathroom. The noise is louder the colder it gets as you describe. I too have a older heat recovery unit that is still operating.
    I cant really help on exactly why it does this because I have learned to live with it.
    Strange though nonetheless.
    Virginia
    is your auxillary heat on
    Go Trump
    Nov 2012
    Not to sound dumb but when you say auxillary heat what are you referring to?
    Sorry took a couple days to reply.
    Also havent been able to record sound yet , but will this weekend then post.
    Thanx for reply
    SZ
    Nov 2012
    Video
    Finally got audio/video of noise but cant upload. Any ideas , maybe to big or not compatable?
    Thanks any info would be great!
    Scotty
    Post it to utube and embed the link to it in a post.
    Nov 2012
    Thanx
    Thanx ! Great Idea.
    Scotty
    Aug 2012
    Los Angeles
    Additional infractions may result in loss of posting privileges.
    Vahe501
    Nov 2012
    Posting Reply
    Did not know I was out of line trying to post a noise I have in my own unit. Was lead to believe this was a thread for homeowners to ask a question about there unit to a Pro. Also got idea of posting audio of noise from member with GlobleModerator under name.
    Sorry if I broke any rules.
    Scotty
    Quote Originally Posted by scottyz View Post
    Scotty
    Please read jpsmith1cm's post again. Look at the name in bold print. That is who he was talking to, not you.
