Results 1 to 10 of 10
11-22-2012, 06:11 AM #1
New Guest
- Nov 2012
- IRAQ
- 3
water / air radiators for Air handling units
I am the owner for HVAC services ,i have 12 water to air coils i need to know the capacity for each one to convert these coils into air handlers can you please help in an law or formula
11-22-2012, 10:42 AM #2
What are the specs?
11-22-2012, 11:22 AM #3
Moved to Tech to Tech Commercial forum.
11-22-2012, 11:26 AM #4
New Guest
- Nov 2012
- IRAQ
- 3
the thing is i have just the material (the coils) there are no spec's i can obtain the pipes size the area and other physical dimensions only
11-22-2012, 11:34 AM #5
Professional Member*
- Feb 2008
- pulaski ny
- 1,616
do they have a model number?
11-22-2012, 11:56 AM #6
New Guest
- Nov 2012
- IRAQ
- 3
No just i have 2 coils with capacity of 60,1 and 16,6 KW and one other has the exchange surface 62,4 Sq.meters
11-22-2012, 01:59 PM #7
- Feb 2008
- pulaski ny
- 1,616
i guess i don't understand. hopefuly someone else can help better than i can. what is the 6 kw? 2 coils with the capacity of 60 what? no manufacturer name or model number is on these anywhere? are these coils supplied by the customer? maybe a supply house can help you.
11-22-2012, 04:44 PM #8
- Nov 2004
- Western NY
- 984
The coils capacity is going to vary,inlet water temperature, water and air flow are variables affecting it, you best bet is to contact the manufacturer and ask for the capacity specs.
the standard formula is BTU=500XGPMX delta T, but thats not going to help you a whole lot.
11-22-2012, 04:50 PM #9
- Nov 2004
- Western NY
- 984
11-24-2012, 02:35 PM #10
- Feb 2012
- New York City
- 106
Best bet in this scenario is to measure the number of rows, tube size, face area and fin density (count the number of fins in 10cm). Then give that information along with the flow and return temps as well as entering air conditions to your air handling vendor and ask him to estimate the performance based on a similar coil tha he currently manufactures and derate what he gives you by 5-10% to account for degraded condition of existing equipment.
