Results 14 to 17 of 17
    Georgia
    Do you still have the inventory? How far are you from Houston? Atlanta. I live in metro Atlanta and have a friend who occaisionally travels from Houston. If you have the inventory I will check with my learned friend for pricing offer.
    Atlanta GA area
    Hi Spike,
    THX for posting the inventory. You have lots of stuff there, some of it I could use and some of it would probably be truck stock for a year or more until it found a home...
    Please contact me at:
    Home dot Service at CHS-Inc dot net
    THX!
    GAhvacTech
    Jan 2002
    Thanks, Benncool!
    for picking up the hand tools and ACR fittings!....
    So, this is what I still have...
    1- Swedge Kit, Ritchie
    1- Motor, GE, 3585
    1- Motor, GE, 3583
    1- Motor, Rescue, Blower, 110v, 1/6-1/2hp
    1- Motor, GE, Goodman OEM, 240, 1/4hp
    1- Mount, Bellyband, universal
    30-' 3/4" Sealtite Conduit Bulk
    1- 45 x 440 run cap
    1- 35/5 - 440 run cap
    1- 50 x 440 run cap
    2- 35 x 370 run cap
    1- 40 x 370 run cap
    1- 40/5 x 370 cap
    1- 35/10 x 440 cap
    1- 55/5 x 370 cap
    1- 80 x 440 cap
    1- 40/5 x 440 cap
    2- 35/5 x 370 cap
    1- 30/5 x 370 cap
    3- GE 30/370V Capacitors
    2- 10/370 Capacitors
    3- 5/370 capacitors
    1- 25/370 cap
    1- 30+7.5/440V cap
    1- Fan relay - Tempstar OEM
    1- Fan relay - Steveco 90380
    1- Fan relay - Steveco 90290
    2- Fan relay - Diversitech 90340 relays
    2- CB, SquareD 30A DP 240v
    2- CB, " 40A "
    1- CB, " 60A " OEM for York/Luxaire AH
    1- Potential Relay - Supco SUPR Universal
    1- T-Stat, Robertshaw 9615 Digital
    1- T-Stat, " 9420 "
    1- T-Stat, " 9415 "
    1- T-Stat, " 9600 "
    1- T-Stat , Honeywell Y5949 1664 HP
    2- T-Stat , W/R 1F57-306
    1- T-Stat, W/R 1F56-444
    1- T-Stat, Honeywell T-87
    1- T-Stat, Honeywell T-87 subbase
    1- Sequencer, Supco 4 stage
    3- Sequencer, 2 stage
    1- Sequencer, 1 stage
    1- Time Delay, ICM, DOB fixed
    1- TD, ICM, DOB, adj
    1- TD, ICM, DOM, adj
    1- TD, Rheem, 2-wire
    1- Drain Pan Cut-off Float Switch
    1- Furnas 2P, 208/240V coil contactor 45EG20AG
    2- Square D 3 PH contactor, 24V coil 8910DPA43V14
    4- Supco 90380 Sequencers
    3- Square D 3PH contactors 208/240V coil 8910DPA43V09
    1- Square D DP contractor 110V coil 8910DP12V02
    1- Furnas 3PH contactor 208/240V coil 42CE#5AEG106
    4- Mars 90295 SPDT relays 240V coil
    20- Asst 3" Cartridge fuses
    2- 60A Square D DP CB
    2- 40A SqD DP CB
    1- SqD DP disconnect
    1- 50A GE DP CB
    1- 20A GE DP CB
    1- 60A GE DP CB
    2- 40A GE DP CB
    1- 15A SP CB
    2- 24" flex NG connectors
    1- 30" flex NG connector
    1- 3/8" Danfoss checkvalve
    1- Alco 1/2" LLD, sweat EK34S
    1- KMP 3/4" SLD, sweat WSL306S
    1- Alco 3/8" LLD, sweat EK164S
    1- Alco 3/8" LLD, SAE, EK164
    1- Parker 7/8" Hi Acid, SLD13, sweat
    1- Sporlan RCVE TXV, 2 ton
    1- Parker 5/8" Hi Acid, SLD85SVHH
    5- 3/4" sealtite connectors
    2- 3/4" sealtite connectros, 90
    2- 1/2" sealtite connectors, 90
    15- Romex connectors, reducers, asst'd sizes
    3dz- Fittings, PVC, asstd
    8- Asst'd circuit boards (used, but still good in box)
    1- T-Stat Lock Box
    Anyone, anyone...?
    Thanks spike
    Apr 2001
    west virginia
    sounds like the parts van I need to have , I dont use alot of the stuff either but it has been hot on these items latley, who do you have marketing you lol
