Results 1 to 12 of 12
Thread: Walk-In Freezer Not Holding Temp
12-13-2012, 10:48 AM #1
The views and opinions posted here are my own. They do not reflect the corporate policies of my employer and will most likely get me fired at some point.
12-13-2012, 12:50 PM #2
Is that the magic "solder"? Doesn't look like there's anything on there!?
12-13-2012, 12:58 PM #3
No way!
Solder compound? The stuff in a red bottle?
sent from my Samsung Galaxy NoteMember of the "Work Exchange Program"
"Will work for knowledge"
"Everyone is a genius. But if you judge a fish on its ability to climb a tree, it will live its whole life believing that it is stupid"
A Einstein
12-13-2012, 01:35 PM #4
WTF is that? Some type of glue?
Local 597 Service Fitter
Metal Trade Journeyman
PAY ME NOW OR PAY ME LATER
It was working when I left...
WWFD
12-13-2012, 02:21 PM #5Member of the "Work Exchange Program"
A Einstein
12-13-2012, 06:52 PM #6
I thought it was called:
HVAC Super Pro
Or something stupid like that. I remember reading "you'll ask: what did we do with leaks in walls, before hvac super pro?"
We used a dang torch. and people were happy at the end of the day.
That product should be named HVAC Super Hack."Better tell the sandman to stay away, because we're gonna be workin on this one all night."
"Just get it done son."
Dad adjusted
12-13-2012, 09:15 PM #7
I don't know what product it was. It was red, resembled a Loctite product, and I was able to break all joinings with only my hands. Whatever they used, it didn't work.
12-14-2012, 01:31 AM #8
- Jun 2003
- 3,633
I've used the HVAC superpro on boiler water pipes once. They were in a wall an needed to be cut and capped and I had to work entirely by feel, they could not be seen to use a torch. It worked excellently.
The stuff I used was purple in color so it probably is not what was used in this case.
The SuperPro has like 10 warnings all over it that you must sand the fitting with coarse grit cloth and LEAVE THE FILINGS on the pipe and fittings. If you wipe them off it won't harden properly.
12-14-2012, 09:58 PM #9
- Oct 2012
- La Crosse, WI
- 233
So was the drier and solenoid put in recently or has it actually been able to run for a while with all the joints glued together with red loctite?
12-15-2012, 12:47 PM #10
12-15-2012, 02:03 PM #11
That is so bad it isn't even funny it's sad
No pride at all!
Did the red magic glue make it hard to solder it? How much of a charge did he loose?
12-16-2012, 02:02 AM #12
I was concerned about bits and chunks of that stuff finding its way into the TXV, so the solenoid valve and all copper in that section were replaced. With a torch and silfos. One jug of R404a later, had a cold freezer.
It's too bad, it would be really cool if there were some 'magic glue' that actually worked.
