Thread: Heat Pump T-Stat settings
    Oct 2006
    Hi everyone, question for the pros. In regards to t-stat settings when used with a heat pump I've heard two things and I'm a little confused. One statement was to set the t-stat at a specific setting and leave it alone (don't turndown when not home). However, I've also heard that if you have an adaptive t-stat it's ok to set the t-stat down more than 2 degrees because the t-stat would adjust the time to bring the temp backup.
    Question, which "practice" is true or more importantly better for overall performance and efficiency. Thanks
    Grottoes VA
    Both
    If you have a stat with addaptive intelligent recovery you will save money by setting it back.
    If you have a none programable stat...leave it alone.
    Set the thermostat for design temperatures and do not deviate from the design temp settings recommended by the designer.
    If you are away for an extended period of time set the thermostat above or below design temps for energy savings.
    You'll have no problems setting the indoor temp. ,above or below the design temp.,but in colder weather it may not be able to maintain much warmer then the design temp..
    Setting it back ,and saving money,depends on how the system controls are setup.It cna be wired with an outdoor stat to prevent auxillary strip heters from coming on ,above the "balance point"(temp a which you need them to maintain temp.),then set back is no problem.
    Using a programable stat,with a recoverry featuere that locks out the strip heat will work too,as suggested above.
    You'll need an onsite Pro to check out how it's wired and advise what can be done.
    I don't care how adaptive or intelligent the stat is, do a setback near at or below the balance point of the house, you will use backup to warm up. Period. An adaptive stat can't make the heat pump put out more heat!
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
