Results 1 to 13 of 31
    Nov 2012
    Hooking up in line fans to boost temperature in one room
    My Comfortmaker system was installed and two in line fans were added to boost the output to one room. The fans were wired to an always on AC connection and as far as I can tell have both burned out over time. I am about to replace them and I see two options - hook them to an AC line that receives power when the furnace is running or hook them to duct stats. My preference is to do the first because it is cleaner, less things to go wrong. I cannot find any documentation on my furnace so I was wondering if anyone had any links to information that will help me figure out if there is a switched 110v coming off the furnace for running accessories? Thanks.
    Mount Airy, MD
    Thread relocated to AOP
    Northeast Ohio
    Care should be taken not to exceed the amp capacity of any control boards or controls on your furnace. Doing so will cause over loads resulting in failures that will be expensive. There are several ways to achieve what you want but site rules prevent any detailed DIY instructions. Any competent local HVAC professional should be able to help you with this.
    DEM
    Saint Joseph, MI
    Two inline fans to boost output to a single room?
    Has anything else been done to balance the system?
    Duct fans should be a last resort after everythign else has been tried.
    Fantech makes some good quality inline mixed flow fans. I have one in my home exhausting my garage that's going on 1-1/2 years running continously.
    I would power it seperate of the furnance and use a relay triggered by the "EAC" output on the furnace board so it runs when the furnace blower runs only.
    Nov 2012
    Thanks for the help. The relay sounds like the way to go. I don't want the fans running all of the time as it will reduce their life and consume electricity. The room is on the outside of the house - a converted porch - with windows on three walls - so it is always cold or hot depending on the season. I am not sure why two fans were installed - I will try hooking them up one at a time.
    Fort Worth, TX
    Did the room ever stay comfortable when the booster fans worked?
    Building Physics Rule #2:
    Building Physics Rule #3:
    I have used pressure or sail switches. If their is poor return with door shut an additional return would probably help.
    Nov 2012
    I can't remember. I don't know how long it has been since the fans have been working. The room is always cold.
    Quote Originally Posted by Shophound View Post
    Oct 2007
    Chicago, IL
    Quote Originally Posted by simonmason View Post
    Think I would spend my time and money on insulating and draft-sealing the room. Converted porch will never be comfortable unless these issues are addressed first, especially with that amount of windows. Boost fans alone will not do the trick.
    More than likely insulation is poor at best, that is where I would look first, if you want to actually make the room usable.
    Hiptech
    perfect solution would be a ductless mini split
    Stuff happens
    Nov 2012
    Thanks for all of the help. I agree that the mini split would be a good solution - albeit a lot more expensive than two duct fans! The room was done properly - insulated, etc. However, it is cold because it is on the outside wall of the house and has casement windows going from 18" above the floor to the ceiling on three walls. So there wasn't much room for insulation except around the bottom of the walls and in the ceiling. There is no return in the room - the closest return is in the next room. The room is mostly laid on a concrete slab although there is access underneath at one end of the room. Would adding a return make much of a difference?
    is the room closed off from the rest of the house or is there a cased opening .if it's closed off it needs a return
    Stuff happens
    Nov 2012
    It has a pocket door into the house and this is always open. The return is just through the pocket door.
