Results 1 to 13 of 15
    Phoenix,AZ
    Powerhead separation!!!!
    Ran across this valve today. It also dumped 6.5 lbs of r-22 into the ozone!!!Should i call the EPA?
    Jul 2009
    Columbia, MD
    freakin' awesome! What unit was it in? Carrier?
    May 2011
    tallahassee,fl
    Wow, that's a first for me!!!
    May 2011
    tallahassee,fl
    Made in china?
    Nov 2007
    Mississippi
    That's just the pressure relief valve doing its job.
    Apr 2002
    Dallas, TX
    By chance was this valve on the indoor coil of a heat pump having a recip compressor?
    If the only tool you have is a hammer, you tend to see every problem as a nail. – Abraham Maslow
    Phoenix,AZ
    Quote Originally Posted by Andy Schoen View Post
    It was on a Carrier energy recovery ventilator and yes it was the supply coil and it's a recip!!!
    southeast
    Never seen that before. I would think there has to be an abnormal amount of virbration to shake these parts apart. I don't believe the complete weld would break popping off the power assembly.
    Just a thought take a good look of the system. There may be somthing going on !
    Very cool.
    Sent from my SGH-T999 using Tapatalk 2
    Andy knows something that he is not sharing!
    Quote Originally Posted by jayguy View Post
    Apr 2002
    Dallas, TX
    Having been a TEV product mangler in my past life, yes I've seen this before. It is not common, however.
    With a heat pump system in the heating mode, and if a TEV is used to feed the indoor coil, discharge pressure will be transmitted to the underside of its diaphragm via the equalizer line.
    Normally this is not a problem for the valve.
    But if a recip compressor is being used, and if the recip compressor is delivering an inordinate amount of discharge pulsations... these pulsations work on the TEV powerhead. The powerheat casing flexes ever so slightly with these pulsations as if it were a drum. The weld succumbs...
    I don't ever recall this happening when a scroll compressor is used.
    nice! thanks!
