Results 1 to 10 of 10
Thread: smoke anyone!
    Dec 2010
    Red oak TX.
    smoke anyone!
    Is their any issues with duct mount smokes in clubs and such shuting down units with smoke machines in use. I need to put 6 in a skateing rink.
    Atlanta,GA.
    most smoke machines are not really smoke it is dry ice and water
    Atlanta,GA.
    but cigarrette smoke is different it really is smoke
    Rochester NY
    Some smoke machines use Propylene Glycol, Glycerin, and Distilled Water (theatrical smoke).
    These, obviously, don't set off smoke detectors (or they wouldn't work in theaters...).
    Oct 2011
    Chicagoland Area
    Quote Originally Posted by tedkidd View Post
    Can you explain. I've had steam set off detectors as well as dust. What is different about "fake smoke"?
    Anytown USA
    Quote Originally Posted by 2sac View Post
    as well as dust
    Ah yes good old dust setting off smoke alarms.. You try to be the good guy and brush off a dirty return grill in a store only to set off the fire alarm and they evacuate the whole shopping mall.
    Nope never done that before.
    Rochester NY
    2sac, I can't, sorry. Just know I use "zero toy" smokers to sniff out air leaks (with a blower door) and you can hold them up to smoke dterctors and they don't go off.
    I think it's basically low temperature steam.
    DONT do that with caustic smoke pencils, they WILL trigger alarms.
    Apr 2012
    winnipeg
    well...... I have..... way to many times....lol ..... fire department gets over it eventually.......
    Oct 2009
    Raleigh, NC
    To provide an answer for your original question, you will have to do some homework. Most theatrical fog machines use a water/glycol or a mineral oil mixture to produce fog. It is vaporized and discharged through a nozzle where it immediately condenses to fog. Water/glycol fog is much less likely to set off fire equipment compared to oil based. The main thing is what type of smoke detectors are present in the space. If they are the optical kind which sense particles in the air, you may have issues. If they are ionization type sensors, you will most likely have no problem at all. Of course, there is the possibility that the space has both!
    Dec 2010
    Red oak TX.
    Thanks to all for the info. has been some time sense i jacked with a detector. I just dont want that late nite saturday call!!!
