Results 1 to 13 of 22
    Oct 2010
    oklahoma city
    how to warm up a centrifugal
    I need to do an oil change on a CVHE. There is no hot water available near the chillers, so I need to find a portable water heater solution to warm the barrel. Preferably without taking 6 hours. Anyone have a piece of equipment they recommend? I think a propane heater would work the best, as the only power sources nearby are 120v or feeds equipment. Thanks.
    Somewhere in the world.
    http://www.westsidewholesale.com/plu...osch-rp7p.html
    You could mabey use some thing like this just a thought.
    A mind is like a parachute. It doesn't work if it is not open.
    The best part of going to work is coming back home at the end of the day.
    Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all.
    You don't need to pressurize a low pressure chiller to do an oil change. You can do it in about 30 minutes with the machine in a vacuum if you've got the right tools.
    The key to happiness is lower expectations.
    Don't pick the fly crap out of the pepper.
    The Hot South
    Quote Originally Posted by Tech Rob View Post
    AGREED!
    I have never heated up a low pressure chiller to do an oil change and it takes me 30 minutes with minimal tools.
    The real simple way is to start the machine get it down to 45 deg. chw nice vacumm shut it down and work on it. You need to be quick about it.
    Float'N Vally, MS
    Quote Originally Posted by bluke1 View Post
    How do you warm up a chiller
    Kiss it gently and tell her how much you love her.
    Life is too short, Behappy!
    TFMM
    One of the guys who used to come on this board had a 123 refrigerant drum that he converted to a vacuum chamber with isolation valves on the inlet and outlet. He would evacuate the drum to a pressure lower than the chiller, open the isolation valve, and it would suck the oil right out of the chiller. Use the vacuum in the chiller to draw the new oil in.
    Invest in a good gear pump and your troubles will be over.
    Aug 2009
    Prattville, Alabama
    Quote Originally Posted by york56 View Post
    +1.
    The Hot South
    We also use an oil transfer pump.
    Jan 2005
    Houston TX
    bluke1 - Okay here it is, no hot water generation needed only 120 volt outlet. From the sump valve on the oil tank connect a 1/2" refrigerant hose to a gear pump inlet side with a check valve on the discharge side to prevent back flow. Leave the sump valve closed at this point. Install a line from the check valve outlet with a sight glass on the end and connect to a vacuum pump, if you have any ball valves that would help. Start the vacuum pump and once the vacuum drops below the level of the sump pressure open the sump valve and watch for oil moving to the sight glass. Valve off the sight glass, shut off the vacuum pump and start the gear pump and drain your 7 gallons into a 100 # refrigerant can (now a waste oil drum) . This doesn't take long, but once your pump looses prime your done. Your can either suck the new oil in or valve off the sump and reverse the gear pump and pump the oil back in the sump. Just remember to purge the air out of the connection at the oil sump before opening that valve. I always pump the oil in as I know I won't get air in the sump. Good luck- GEO
    Once in a while everything falls into place and I am able to move forward, most of the time it just falls all over the place and I can't go anywhere-GEO
    Oct 2010
    oklahoma city
    Thanks for the advice. I have researched the question before I asked here. The local trane office told me that their method was to warm the chiller. I have searched gear pumps, but most seemed too large, high gpm. Can anyone be specific on the manuf. and model of the pump you are using?
    Jan 2005
    Houston TX
    bluke- You don't need a high dollar hydraulic oil pump, I have a 1/2 hp, 120volt pump that came from W.W,Grainger. Yes, it is preferable to heat the entire vessel up as then you can also do a leak check. bluke please remember though you ask for advice and got it. The guys on hvac-talk.com have years of experience doing this and have been in your situation long before we had this easy method of getting professional advice. I have almost 30 years myself and I still request information from others. Like the man said "Ain't none of us as smart as all of us". I am a professional technician in training and will be for years to come. Good luck -GEO
