    Apr 2008
    Delray Beach, Florida
    Condensate Line Maintenance
    Anyone out there try the Jones (line drive) valve, Easy Klear, Water Wizard or AC Easy Tee devices on drain lines.
    Looking for the best product to install in line to have access to clear and maintain it without cutting the line or using clear hose? Looking for feedback on any of these or others.
    May 2009
    Cumming, GA
    We have been installing the EZ trap for years.
    http://airtec.rectorseal.com/condensate/eztrap
    1. Easy access for drain cleaning thru the large red caps.
    2. The brush that comes with it is great for all traps cleanings.
    3. The actual trap is clear for indication of clogs.
    4. Built in float switch to disable the system before the emergency pan fills up.
    Overall, a great product.
    Float'N Vally, MS
    Quote Originally Posted by soaker View Post
    Saw that @ Genaire last week. About two years ago, I was asked by a HO to put in a block valve in the drain line for clean out. I refused but now I believe he was asking bout this.....
    Curious about this also...
    Life is too short, Behappy!
    TFMM
    Dec 2009
    Union Nj
    My job always use the ex traps from the above post. Very easy to clean and easy install.
    Oct 2010
    Hanover, PA
    Ez trap
    Quote Originally Posted by Brent Ridley View Post
    Our company uses the ez trap as well, they work very well, easy to clean and float switch shut off is a nice feature. We also add an additional float switch in the secondary drain just incase it should fail for redundancy.
