Results 1 to 7 of 7
Thread: Carrier 48GS
    Hmm
    When my unit is running,shortly after the burner starts,the flames begin to "cut out",but when I open the front access panel a bit the unit performs as normal.I did not see anything clogged up inside the combustion chamber,also the flames at the burners are blue when running normal.What else other than the flame sensor could cause the flame to want to die out with the front panel fully secured ?
    [Edited by techman2006 on 11-06-2006 at 11:03 PM]
    knoxville ,tn
    Leave the door off "LoL"
    Oct 2006
    clean ur flame sensor with sandpaper or check the hose of the presure switches
    Jun 2001
    Louisville, KY
    How do either of those affect the combustion process?
    BTW...welcome to the boards. I appreciate your enthusiasm, but ease up a bit on the step-by-step advice. I had to trim one of your posts in another thread.
    Has someone replaced your draft motor lately?
    Mar 2006
    cincinnati, ohio
    when you say clogged up are you referring to the filter
    Knowledge comes with experience
    knoxville ,tn
    I had a trane package system a while ago that did the same thing it ended up being the gasket around the inducer assembly,also if it's a 90% furnace your intake could be slightly blocked.
