Results 1 to 11 of 11
    Oct 2002
    reverse valve failure at pilot cap
    I am relaying this issue from my very experienced tech.
    reversing valve on a goodman R22 HP has been failing at cap-pilot connection, either at hot gas or suction.
    4 and counting.
    Goodman has suggested many solutions, all followed but no inprovements.
    No vibration seen, no slugging, new compressor with looped hot discharge to absorb vibration.
    Anyone Seen this?
    Oct 2002
    Wow. No one has an idea?
    Jun 2009
    Upstate SC
    Quote Originally Posted by timjimbob View Post
    Have you changed 4 reversing valves on a Goodman unit?
    I hope not because it would have been easier, cheaper, faster, and probably much less headache to change the unit.
    Sent from my ERIS using Tapatalk 2
    Oct 2002
    Would have if it wasn't R22. Goodman warranty some valves.
    Jun 2009
    Upstate SC
    I understand the valve is under warranty, but are you eating the labor to do all that or is the customer?
    4 reversing valves and a new compressor and it's still blowing the cap tube..... hmmm
    Did this just start since the heating season?
    Oct 2002
    No heating here yet!
    Not sure, but I think been dong it since last year.
    Not customer.
    Oct 2002
    4 times since 2008
    Jun 2009
    Upstate SC
    So the info is from your tech, but it's not your customer.....
    Step in and sell them a new unit.
    Oct 2002
    my customer. Unit was new when problem started
    Hell Hole Swamp
    Chinese Kwality
    Apr 2005
    AZ
    I've only had one unit that busted a pilot tube more than once. 2 times within a couple months or something like that. I went out to do the 2nd and found poor connection causing a chatter. Can't remember if it was contactor or valve chattering but it took care of it. It was a 410 unit but...
