Results 14 to 26 of 50
    Mar 2010
    Morgan Hill Ca.
    Quote Originally Posted by jayguy View Post
    it is a WHAAAT???
    Porn needs servers too...
    If a day goes by and you have learned nothing, I hope you got a lot of sleep.
    Jun 2010
    U.A. (upper Alabama)
    it is a WHAAAT???
    Hey Jay! Sex sells you know.
    The Hot South
    I guess thats where they catalog all the DNA for the crime lab....
    Mar 2009
    Mid-Mo
    Have you called Benshaw's tech support line yet? They are awesome, I suggest you do that first.
    As for getting crazy sealing things, I have had great luck sealing flow switches and freezer conduit with a product called duct seal. It's a putty that you basically stuff in the hole around the wires.
    http://m.lowes.com/pd_13591-12704-31...ductId=3127723
    Jul 2009
    In a mechanical room....
    How many feeders are fed into the plant from the utility ? Is there an voltage imbalance? Amprage imbalance?
    “It takes courage to grow up and turn out to be who you really are.”
    - E.E. Cummings
    Mar 2011
    Malaysia
    Quote Originally Posted by Octopus View Post
    2 feeders and i have checked the voltage - there is a slight imbalance but it has been like that for years - (its 415V here) - we are generally looking at 411, 412, 412 most of the time. The voltage fluctuates +-3 volts max.
    There have been surges (voltage spikes once in a while).
    Mar 2011
    Malaysia
    Quote Originally Posted by ryan1088 View Post
    Thanks for the tip on the seals.
    I have yet to call Benshaw. Will do that and update on the outcome here.
    Mar 2011
    Malaysia
    Quote Originally Posted by cperk View Post
    http://en.wikipedia.org/wiki/Cum - depends which angle the mind is leaning towards ...hahah
    Sex does sell! got more attention than "chiller trip"
    A land down under
    Quote Originally Posted by HVAC_MY View Post
    "its 415v here, location in the Tropics, Centravac R123, 2 stage centrifugal at the same site" - so I assume with AFD if on 50hz supply, can I ask your location?
    Also you have no details in your profile that assists the the decision to provide suggestions towards a resolve.
    Necessity is the mother of invention
    Jul 2009
    Seen same thing the plant had two feeders. Primary and secondary if the primary feeder failed it switched and it tripped the chillers, had utility log site and he found an entire cap bank on one phase of the secondary shot, when they fixed the bank the plant was no longer problematic.
    - E.E. Cummings
    oh, i know that...why do you think it takes me a long time to get around to logging in here! those girls aren't going to get through college by themselves!
    TMI?
    Jun 2010
    Quote Originally Posted by Screwit View Post
    Good eye Screwit! Should be 3 stage on 50 hz, due to the lower rpm of the motor.
    Jun 2010
    TMI?
    DING! DING! DING!
