Results 14 to 26 of 39
    NE wisconsin
    Quote Originally Posted by terpfan_ View Post
    never understood why all transformer don't come with built-in breaker.
    Then the transformer manufacturer wouldn't sell any transformers
    in a house, Appomattox, Va.
    I like the multi fuse idea to narrow down cause.
    Col 3:23
    Jun 2012
    Fayetteville, NC
    I ran into something similar a few weeks ago, went through 3 transformers before i finally wised up and asked a senior tech.
    Austin, TX
    If I am blowing transformers I just don't put another one on until I find out whats making my VA to high. Chances are its cause someone took a 75VA off and replaced it with a 50VA.
    If you're too "open" minded, your brains will fall out.
    Artificial intelligence is no match for natural stupidity.
    Jun 2012
    East tx
    I always carry a transformer with a built in circuit breaker when i come across a bad transformer... I use it as a troubleshoot aid
    Aug 2009
    Las Vegas
    Just check your wires for a short
    Nov 2012
    East TN
    Is it blowing on the primary or secondary side?
    Oct 2011
    Chicagoland Area
    Get some fuses and get your post count up
    Nov 2012
    Arlington, TX
    Quote Originally Posted by jledford382 View Post
    Blowing the primary.
    Nov 2008
    DFW,TX
    use a resettable in line fuse until you find the issue and make sure you check anything and everything related to the low volt system, sounds like a bare 24 v wire that is rubbing on metal or another bare wire next to it that goes common..Ive found many outside in the condenser cabinet especially on heat pumps where the wires have been tied to copper pipes eventually rubbing through.. keep looking and you should find it , id say look at running new aire from stat to AH as its happening in heat and cool or its in the Tstat itself..
    Nov 2007
    Mississippi
    You have a direct short. Ohm out all wires and isolate.
    Nov 2012
    East TN
    Yep sounds like a direct short as already stated. I had the same problem a few months back. I put a Lil' Popper in and blew probably 12 fuses before I found it. It was an older house with terrible wiring. When I finally found the problem, someone had spliced wires about 15 feet from the panel and just taped it up with electrical tape. I assume they didn't have enough wire to finish the run, but that didn't make me any less upset. The house could've very easily burnt to the ground.
    Dec 2009
    Union Nj
    I had this issue, in ny a rat chewed on the tstat wire and shorted every time. Just need to ohm wires.
