Results 1 to 13 of 39
    Nov 2012
    Arlington, TX
    Blowing transformer in air handler
    I am at my wits end with this air handler. I have replaced the the transformer 7 times in the last 3 months. I have replaced every component in the control box, the heat strip and replaced the control box itself. I've also replaced the thermostat in hopes that this would resolve the problem. The system is a First Company Horizontal Fan Coil HX series pumping R22 through a Bryant 3 ton condenser. This problem begin during the summer. The resident would get at least a week of no problems with the condenser and then the transformer would blow. We are now in heating season and as soon as the 10Kw strip is energized, there goes yet another transformer. Any ideas of what may be causing this aggravation and why it isn't happy with heating or cooling?
    Central WA
    Sorry, we cannot give DIY advice here. I will tell you this, however: fuses cost less than transformers.
    Nov 2012
    Arlington, TX
    Quote Originally Posted by cjpwalker View Post
    I am not a DIY. I am HVAC certified and have been for the past 2 years. Thanks for your reply, anyways.
    Houston,Tx.
    Quote Originally Posted by micsand View Post
    Then you should know to fuse the transformer until you find the issue and you would not be replacing them.
    __________________________________________________ __________________________________________________ _________
    "The critic is a prisoner to his own experiences and perspectives, erroneously believing his limited experiences are the sum of all truth".
    Baton Rouge, LA
    I could tell you what to CHECK but because of your status does not Verify you as a certified professionAl we would be breaking the rules. I hope your TRANSFORMER issue gets resolved.
    If you're too "open" minded, your brains will fall out.
    Artificial intelligence is no match for natural stupidity.
    Nov 2012
    Arlington, TX
    Thank you cjpwalker and Mr Bill for the advice. I appreciate your responses and will do so. Just been a long 3 days of trying to isolate this problem. I have run into this issue several times with other units and have been successful with correcting the problem. Been going through my notes and talking with other techs. I'll get it solved, just need to figure what I missed.
    Southeastern Pa
    Since you are new...
    1) get 15 substantive posts under your belt and apply for Pro membership
    2) when you get Pro membership, post in the Pro Residential forum. We don't post a lot of technical info here in the open forums, because they are easily indexed by search engines.
    Oct 2002
    Fuse every load, then determine where your problem is.
    Your trouble shooting skills are poor. Be more systematic. Learn, advance to next step. Replacing same part over and over is wasting your bosses time and inventory.
    Nov 2012
    Arlington, TX
    I appreciate your response. I'll get it. It hasn't beat me yet. :-)
    Nov 2012
    Arlington, TX
    I appreciate your candor. Your are absolutely right and is wasting my time as well. I am still learning and improving everyday. Thanks.
    Houston,Tx.
    Hey, I can remember back in the early 70's when I was kicking off, I would carry 10 transformers because I had to learn from someone to fuse them also.
    Nov 2008
    baltimore
    never understood why all transformer don't come with built-in breaker.
