Page 4 of 4 FirstFirst 1234
Results 40 to 52 of 52
  1. #40
    I would go back over that HX install again with a fine tooth comb.
    I know the burners have a particular way they lay on each other that might be another thing to check, along with alignment in the opening.
    Gravity might have already sent it too you, but I'll email you a pdf of how they go together.
  2. #41
    Nashville,Tn
    That was the problem!!! The inducer draft motor was wired wrong. I had the brown where the purple should be! Changed these two wires and it fixed it!
  3. #42
    Glad you found and resolved the issue. I still want to know how the CO levels rose in the building
    Sent from my HTC Sensation 4G using Tapatalk 2
  4. #43
    Nashville,Tn
    Me too! I was thinking about that myself!
  5. #44
    Jul 2009
    Columbia, MD
    So, your inducer was spinning backwards?
  6. #45
    Mar 2010
    Arnold, Mo
    Quote Originally Posted by hvac wiz 79 View Post
    On the talk of carrier. Anyone have the parts app? It's been good so far. One of the carrier distributors around here has a very lackadaisical counter guy. When I'm forced to go through him I have found to sometimes double check because he has screwed up. For instance quoting me a 3ph cond motor when I knew for a fact the one in question was 1ph. Anyway, its the CE app
    Sent from my SCH-I800 using Tapatalk 2
    Where did u find that app? I couldn't find it online.
  7. #46
    Quote Originally Posted by flanders View Post
    http://www.carrierenterprise.com/
    On the bottom right of the page.
  8. #47
    Mar 2010
    Arnold, Mo
    Thanks!
  9. #48
    Your welcome. I hope you find it useful. That app prevented me from being 2 hours away with the wrong parts.
  10. #49
    Chicago, IL
    Package units are not perfectly sealed, if theres a 10000 PPM cloud of CO surrounding the unit, some of its going to get sucked in through the seams, such as the filter door.
  11. #50
    Quote Originally Posted by craig1 View Post
    Makes total sense.
  12. #51
    Ran a call the other day identical to this thread. Odor was strong with CO levels around 15ppm. Heat exchanger was ok and draft motor rotating the right way. No economizer package to allow extra infiltration. Long story short gas valve inlet 7.9 outlet 6.0. Natural gas. Replace valve all good. The previous response to my question sunk in much more after this call
    Sent from my SGH-T999 using Tapatalk 2
  13. #52
    Jan 2015
    Quote Originally Posted by helsonbm View Post
    Everything is basically new. New heat exchanger, inducer assembly, back plate, gas valve, and the 2 inshot burners. I called Carrier and there is no regulator or flame retainer for this piece of equipment. They doubled checked too. The alignment of the burner is right on as well. Sealed with high temp caulk, didn't go crazy with it but there is plenty to make a good seal. Not sure what else to check. The outlet pressure is a least 3.5 to 3.7. That model was a 48GS-030060301 by the way.
    I had this problem. Cleaned the soot from the burner and seems to be working. I plan to go back and pull the inducer and look at it.
    Alvin
