Results 14 to 26 of 51
    NH
    So did you install the flame retainer and regulator?
    Never mind missed the last post
    Interesting thread. Draft motor rotating the right way?
    Sent from my SCH-I800 using Tapatalk 2
    NH
    Is this natural gas?
    I would also check to make sure the draft motor is the same, rpm, wheel, rotation ect.
    NH
    To slow tonight I guess.
    Jul 2009
    Columbia, MD
    i dont believe carrier. i called them yesterday about a motor mount kit. They swore up and down that this motor mount kit worked for the same unit i replaced the heat exchanger. I called them and verified the part I had in hand would work.
    Well guess what. It didn't work. I couldn't even rig it to work.
    On the talk of carrier. Anyone have the parts app? It's been good so far. One of the carrier distributors around here has a very lackadaisical counter guy. When I'm forced to go through him I have found to sometimes double check because he has screwed up. For instance quoting me a 3ph cond motor when I knew for a fact the one in question was 1ph. Anyway, its the CE app
    Jul 2009
    Columbia, MD
    for your unit i see a flue baffle in the parts list
    flue baffle; 48GS500114
    and NOx baffle
    insulation; 48SS500601
    how many pipes on bottom did you h/x have?
    I would try the 2 parts i listed above
    Nashville,Tn
    2
    Nashville,Tn
    i noticed that both part #'s have a 500 in it but the part #'s i have for two of the parts have 400 in them. Such as the inducer fan assembly is a 48gs400649 and the flue box collar is a 48gs400108. I do not know if this means anything?
    Nashville,Tn
    sorry about the slow responses, I just had my first child two weeks ago and I have been trying to spend some time with him!! It is natural gas. That is a good idea on the draft motor. I will check that!
    Jul 2009
    Columbia, MD
    your parts numbers are right and the ones i gave are correct.
    the new heat exchanger comes with the NOx baffle. so dont worry about that.
    i would try the flue baffle. ill send you a pdf
    Jul 2009
    Columbia, MD
    congratulations! I have my second one on the way in May. don't know the sex yet.
    Jul 2009
    Columbia, MD
    have you checked the orifices?
