    I am thinking about replacing a 25 yr old furnace and central air system. I have a 165,000 btu lennox for my 2400sq ft home. short cycling is a problem as well as not be able to cool in the summer. we are thinking about going with a bryant 80v furnace with a bryant 13 seer a.c with puron and the evolution control. my questions being, 1, variable speed or two stage for our home. 2, how is the reliability of the variable speed furnace and the evolution system. 3, puron vs r22 should I spend the little extra on the puron? 4,how is the reliability of the puron systems? thanks, joe
    Variable speed is the indoor blower, and 2 stage A/C's work better with VS blowers.
    The VS blowers are very reliable.
    No problems with r410a(puron).
    Get aload calc done to make sure you get the right size furnace and A/C.
    Seattle, WA
    Our distributor keeps telling us the GE variable speed motor is made in Germany and is considered bulletproof.
    Near Chicago, IL
    Get a load calc.
    Make sure the ductwork is OK.
    "Puron" has been around for a long time. Make sure it is installed right. Puron will be the only game in town after 2007. Puron problems are caused by shoddy installs.
    Everyone is using GE VS motors. Might want an add on surge protector to protect the electronics in the motor- they ain't cheap.
    Proper Prior Planning Prevents Piss Poor Performance
    "There is hardly anything in the world that some man cannot make a little worse and sell a little cheaper, and the people who consider price only are this man's lawful prey. It's unwise to pay too little.
    When you pay too much, you lose a little money -- that is all. When you pay too little, you may lose everything, because the thing you bought was incapable of doing the thing it was bought to do.
    The common law of business balance prohibits paying a little and getting a lot -- it can't be done. If you deal with the lowest bidder, it is well to add something for the risk you run. And if you do that, you will have enough to pay for something better."
    John Ruskin
    Central Kentucky
    As others have said that equipment will only be as efficient as the ductwork it is attached to.
    Be sure the ductwork is done correctly delivering the proper amount of airflow & BTU's where it is needed.
    Then make sure they set up the equipment properly & you should be pleased with that equipment package.
    Have you set up a Google alert for Carbon Monoxide yet?
    Click here to find out how.
    Apr 2005
    Kingston Ontario Canada
    In other words manuel J and manuel d are the most important as anything else. With the short cycling and 165,000 btu you have right now, you may be oversized.
    Thorton
    _______________________
    The currents that determine our dreams and shape our lives flow from the attitudes we nurture every day
