Results 14 to 19 of 19
    Mar 2012
    Georgia
    Carrier 38AKS condensing units with 2 fans do this too. #2 fan rotates backwards while #1 runs, when #2 is energized, it continues to run in wrong direction. A new capacitor fixes this.....for a while!
    Salem, WI US
    Quote Originally Posted by GoColts View Post
    What he said is true, had this happen to me before, got another new motor and magically it ran the right direction.
    Have to be careful with York Equipment they run condenser fans in reverse to maintain system head pressures.......usually 3phase equipment though....
    Mar 2012
    Georgia
    I have not seen that before, interesting. Must have a second contactor to run fan in opposite direction.
    Sep 2010
    miami,fl.
    Quote Originally Posted by Sicofthis View Post
    Wound for opposite rotation. Factory mix up. It happens.
    maybe at the factory they put the rotor in the wrong way. could have tried flipping the rotor.
    Southeastern Pa
    Quote Originally Posted by Betabass View Post
    Now that's one I haven't run across. Do you have a model number on that?
    Mar 2012
    i have had the trane motor run in reverse before, i flipped the fan blade to get them by untill the new motor arrived. not the best. high head, also had to run a sprinkler on the coil. great for roof leaks.
