Results 1 to 13 of 19
    Nov 2012
    Confused Trane Voyager Condenser Fan Problems
    So i replaced a condenser fan motor capacitor and fan blade on a Voyager Rtu and when i fired it up the motor was spinning backwards, its a single phase motor, so i was alittle puzzled, i called Trane and they were alittle confused as well, suggested i swap the wires from the contactor and capacitor, motor was then spinning correctly but drawing about 1.5-2 amps higher than what it was rated for. So bottom line getting a new motor and capacitor from trane and trying it again. Just wondering if anyone has had anything similar to this?
    May 2002
    Baton Rouge, Louisiana
    Was it a 3 wire fan motor?
    very soon it is you that will be pwned
    If there are 2 fans
    The second one can start backwards.
    Ive seen it.
    Jul 2009
    Columbia, MD
    Quote Originally Posted by supertek65 View Post
    Ive seen it.
    X2
    Mar 2011
    Long Beach, CA
    What is the Model Number of the RTU?
    Nov 2012
    There is 2 compressors, and 1 condenser fan, the mod number was YCD120C4L0AB....and it was 3 wire motor Trane suggested swapping the black wire on the contactor with the purple wire off the cap and it seemed to correct the problem other than the high amp draw and the door was on the unit lol.
    Oct 2011
    Double check the motor, cap and blade, just cause they're new, doesn't mean they're the correct ones, Trane makes mistakes too. Got a 208v compressor in a 460v box before. Didn't run very long.
    Sep 2006
    Ohio
    Sounds like the motor is bad. I'm not sure if you replaced the motor, capacitor and blade or just the motor capacitor and blade. If it was a new motor, you got a bad one. I have purchased several motors from Trane that were bad out of the box or only lasted a day or two.
    May 2002
    Quote Originally Posted by ErikNeMechnical View Post
    Exactly what I thought and why I asked, I myself have done it more than once(we have a ton of Trane Voyagers around here) and that is the proper fix.
    Now on the high amp draw is the capacitor the same size? When you changed the fan blade did you put it in the same place?
    Nov 2012
    Yeah fan blade is in same place capacitor is good, just swapped the motor and cap with another new one and its working great now... Weird **** but atleast I don't feel to bad now that some of you guys have experienced this.
    Apr 2012
    Louisiana
    Wound for opposite rotation. Factory mix up. It happens.
    Feb 2011
    Sacramento, CA
    Quote Originally Posted by Sicofthis View Post
    What he said is true, had this happen to me before, got another new motor and magically it ran the right direction.
    I have done so much with so little for so long, that now I can do almost anything with nothing at all.
