Results 1 to 6 of 6
    Question honeywell Hawk with COACH AX problem.
    Hi there! Can someone help, please?
    I cant connect hawk controller...
    Lan 1 port - 192.168.0.122 (Connected to switch)
    Lan 2 port - 192.168.1.122 (Connected to PC)
    I can ping both of them
    https://dl.dropbox.com/u/46660587/HA...012_134301.png
    But i still can't connect with web interface or Coach ax program. What can be the problem?
    additional hardware info...
    https://dl.dropbox.com/u/46660587/HA...2_133622_0.png
    https://dl.dropbox.com/u/46660587/HA...2_133622_1.png
    ...Connected with rs 232 to change subnet of one of ports.
    Kind regards. Vadim...
    Mount Airy, MD
    Thread relocated to the "Controls" section of the site.
    Oct 2007
    England
    Check your antivirus isnt blocking the port 3011
    San Diego, CA
    https://www.niagara-central.com/ord?...ionThread/8168
    didn't use the commissioning wizard, did ya?
    call support.
    Click image for larger version.
ID:	326821Click image for larger version.
    This should help you correct your libcpp-so-4 issue
    Also read this blog about upgrading / downgrading.
    http://www.niagara-central.com/ord?p.../BlogEntry/154
    Thank you! I will try today!
