Results 1 to 11 of 11
Thread: heat pump odor
    California
    I have a ten month old 13 seer hvac system with puron technology and all new ductwork. About four months ago I noticed an antifreeze like odor near the return. Now there is a heavy almost putrid odor coming through all of the vents. It is worse in the airconditioning mode. Does anyone have any idea what is causing this. Unit has been inspect twice by installer, can't find anything. Carrier, 38YXA, 5 ton.
    [Edited by rhondaj on 11-03-2006 at 11:49 PM]
    Apr 2001
    Arkansas
    Do a search on "Dirty Socks Syndrome".
    "FIGHT CRIME: SHOOT BACK"
    Jan 2005
    Emerald Coast
    rhondaj,
    would you post the model numbers please, thanks.
    Dave
    Do not attempt vast projects with
    half vast experience and ideas.
    flex duct under the home?
    maybe a raccoon decided to make a home in there.
    then died.
    Oct 2006
    Emerald Coast, FL 30.1N 85.8W
    Frown
    If the installer can't diagnose the problem, I say that stinks.
    bad smell
    is your unit under a house in a crawl space or in an attic or in a finished basement and is it in the south east dirty sock is primarily a problem in the south east.but i have never seen it on a unit thats in an attice
    California
    Re: bad smell
    California
    Frown bad smell
    Unit is in the attic, dry climate, California. Entire system is new.
    California
    Dirty socks syndrome
    I have been looking into the 'dirty socks syndrome'. Does anyone have definitive answers to cause and/or remedy?
    The only permanent fix I have found is a coated coil. For Trane equipment I can get them from Trane, I don't know if Carrier has such a thing though.
    For brands other than Trane we order a brand new coil and send it off to Technicoat.
    California/Nevada
    check to see if they drained your condensate into the sewer line on the roof.
