Results 14 to 26 of 48
Thread: Water hammer
    Dec 2008
    Ontario Canada
    Quote Originally Posted by alcomech View Post
    Turn off as many fixtures at there shut offs located under the sinks, cabinets, etc. and see if there is a fixture in particulate which is suspect.
    Good call.
    Dec 2008
    Buffalo NY
    Check your incoming water pressure. Does that tank have heat traps on it? I have seen them cause this type of issue before. With the fast close valve on the fixtures and appliances and the traps it will cause water hammer issues.
    To the man who always did it right. I love you dad and I will miss you to much for words.
    Stay Thirsty My Friends
    Support the Skilled Trades Don't DIY
    Dec 2008
    Ontario Canada
    What's a "heat trap"?
    Dec 2008
    Buffalo NY
    Quote Originally Posted by LKJoel View Post
    They are a galvanized and plastic nipple with a check valve. You would make your piping connection them with a female adapter. They are there for energy efficiency.
    Dec 2008
    Ontario Canada
    Quote Originally Posted by qwerty hvac View Post
    Would it be obvious to spot on the tank?
    Dec 2008
    Ontario Canada
    Tank is a GSW
    MOD#: 6G50NVH-FV-02
    50 Gal 38,000 BTUH
    Don't see anything unusual,
    I did try giving it a good hot flush, no improvement
    Chicagoland
    It should have heat trap nipples, most do. Did you use dielectric unions to connect to the piping?
    Dec 2008
    Ontario Canada
    Quote Originally Posted by AccurateHT View Post
    No, just 2 x 3/4" male pipe threads on the top of the tank, I connected with 2 copper female adapters
    Chicagoland
    The male stubs could be heat trap nipples, if you sweat the adapters while threaded on to the stubs they could have melted. Around here we are required to install dielectric unions or similar (i.e. brass transition fittings).
    Lancaster PA
    You moved the tank from the middle of the house. If the water lines coming down to it when it was in the middle were fairly long. they may have been absorbing the shock. And when you eliminated that drop, you removed the shock absorption ability. Just a WAG.
    Dec 2008
    Ontario Canada
    I definitely know better than that. I sweat the adaptor, short length of pipe and valve together before attaching to tank.
    But it's still worth pulling and inspecting
    Are they typically removable?
    Feb 2012
    Toronto Canada
    LKjoel what part of ontario you from?
    Chicagoland
    Yeah their just regular pipe nipples with plastic centers. Like anything factory installed there gonna be tight!
