Page 3 of 3 FirstFirst 123
Results 27 to 37 of 37
  1. #27
    Jun 2001
    Quote Originally Posted by gravity View Post
    I hear ya. "It's been that way for years. There is nothing wrong with it. You lie, get out my house"
    Yeah, makes you wonder why they called you to begin with...
  2. #28
    Sep 2012
    The way the IAQ works is it has 3 wires going to the thermostat from the EIM (interface module mounted near the furnace). The EIM is then wired to the furnace as most thermostats would be. It's a great thermostat and can be set up to control dehumidification in the summer. I agree with the suggestion to look into having one installed.
    Thanks for the info. I just remembered that the thermostat for our downstairs system is a Honeywell visionpro IAQ. Our downstairs system is a dual fuel system and has a single stage furnace (which is a Lennox G40).
  3. #29
    Quote Originally Posted by 545GAlady View Post
    Is it true that it does not need a w2 wire? I thought that all thermostats compatible with 2 stage heat must use a w2 wire to control 2nd stage.
    The IAQ uses an interface module, known as an EIM. The EIM is mountd at teh furnace, and the furnace wires connect to it, including a W2 wire. Only 3 wires are used to connect to the thermostat on the wall.
  4. #30
    the answer to your question is yes, but....
    IF your thermostat has a W2 then it is best to use it in most cases.
    IF your thermostat does not have a W2, most furnaces can control the second stage by the board in it.
    IF you use a more advanced thermostat, like the IAQ or others, the portion the home owner interacts with needs only 2 to 4 wires. HOWEVER, there is a remote module that has all the necessary terminals and it usually gets mounted near the furnace.
  5. #31
    Sep 2012
    Thanks. I can completely understand now. So the W2 wire will run from the furnace to the EIM. It will be a lot easier for the tech to install a Honeywell IAQ thermostat instead of having him run a whole new wire to the current thermostat from the furnace.
  6. #32
    Sep 2012
    Quote Originally Posted by pacnw View Post
    Thanks very much. I appreciate the info. I'll look into the possibility of having an IAQ installed.
  7. #33
    Sep 2012
    One last quick question... What's your opinion on the Prestige IAQ Thermostat? I'm trying to decide between the Vision Pro IAQ and the Prestige IAQ.
  8. #34
    Jun 2001
    Here's another thread that may help:
    http://hvac-talk.com/vbb/showthread....Vision-Pro-IAQ
  9. #35
    Sep 2012
    That thread was very helpful. Thanks! I will be going with the Prestige 2.0 IAQ over the Vision Pro IAQ. I like how the Prestige 2.0 can connect to the Internet which means I can adjust the temperature on my iphone as well as on the computer. This is something that the Vision Pro IAQ does not have. Thanks again! I appreciate it!
  10. #36
    Apr 2010
    Austin
    This is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise here. Please apply to the AOPC today, thank you.
  11. #37
    CHAINIK, , this is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise here. Please apply to the AOPC today, thank you.
    Your post has been deleted.
