Results 1 to 12 of 12
11-10-2012, 02:30 PM #1
- Jan 2011
- 503
Not sure where in the hell the foil came from.
dirty evap I took out yesterday.
11-10-2012, 02:32 PM #2
Professional Member*
- Dec 2010
- The Quad-Cities area (midwest).
- 1,762
The foil is the least of the problems! That's about as dirty as I've seen.
11-10-2012, 04:35 PM #3
- May 2000
- Urbandale IA. USA
- 4,526
That is not an evaporator coil, there aren't any fins.....
.Those who dance, appear insane to those who do not hear the music.
Those who believe, appear ignorant to those who do not know God.
11-10-2012, 05:00 PM #4
That's a high efficiency direct contact filter, no dirt gets through now
the foil I guess makes it electro static!!!! Lol!
11-10-2012, 11:42 PM #5
- Jan 2011
- 503
1980 something Bard coil. Changed the system. Coil sits in the scrap coil pile now.
11-11-2012, 09:06 PM #6
good place for it......
11-11-2012, 09:20 PM #7
I would have to guess that after the coil clogged and the air flow stopped, the furnace burnt the foil off of the insulation in the heat exchanger box. Now that is assuming the coil sat on a furnace. I have witnessed that before and it's not pretty. Might want to check the heat exchanger if I'm right.
Every problem gives us the opportunity to choose from several solutions: stupidity, ignorance, indifference, or brilliance. Which one will you choose?
11-11-2012, 10:52 PM #8
11-11-2012, 11:19 PM #9
- Jan 2011
- 503
Old lowboy furnace. Can't remember the name. Had cleveland in it i think. I got the emblem somewhere. No foil inside that old puppy!
11-12-2012, 07:39 AM #10
- Dec 2010
- 1,762
11-12-2012, 08:16 AM #11
11-12-2012, 09:47 PM #12
- Jan 2011
- 503
Yessir!
