Results 1 to 12 of 12
    Jan 2011
    Not sure where in the hell the foil came from.
    dirty evap I took out yesterday. Name:  2012-11-09_09.10.29.jpg
    Dec 2010
    The foil is the least of the problems! That's about as dirty as I've seen.
    Urbandale IA. USA
    That is not an evaporator coil, there aren't any fins.....
    Those who dance, appear insane to those who do not hear the music.
    Those who believe, appear ignorant to those who do not know God.
    May 2011
    tallahassee,fl
    That's a high efficiency direct contact filter, no dirt gets through now the foil I guess makes it electro static!!!! Lol!
    Jan 2011
    1980 something Bard coil. Changed the system. Coil sits in the scrap coil pile now.
    Apr 2012
    winnipeg
    good place for it......
    Mar 2009
    Triad - North Carolina
    I would have to guess that after the coil clogged and the air flow stopped, the furnace burnt the foil off of the insulation in the heat exchanger box. Now that is assuming the coil sat on a furnace. I have witnessed that before and it's not pretty. Might want to check the heat exchanger if I'm right.
    Yes, I've seen that before and it doesn't mean I like it.
    Jun 2006
    SW MO.
    Quote Originally Posted by Keith73 View Post
    X2
    Jan 2011
    Old lowboy furnace. Can't remember the name. Had cleveland in it i think. I got the emblem somewhere. No foil inside that old puppy!
    Dec 2010
    Quote Originally Posted by jimmyed View Post
    Lowboys had low airflow to begin with. It probably had a large plenum and then insert the tiny coil opening.
    Athens, Ohio
    Was it Cleveland Dornback?
    Jan 2011
    Yessir!
