Page 8 of 10 FirstFirst 12345678910 LastLast
Results 92 to 104 of 118
  1. #92
    Sep 2012
    I believe I recall you saying this XR15 worked well in cooling mode and was only problematic in heating mode. The fact that they have had to take out charge twice to prevent the high limit switch from tripping makes me wonder how the system will perform (comparatively) in cooling mode once it gets warmer out. Low indoor airflow causes high head pressure in heating mode -- I would not be surprised if airflow was the source of these issues. It's too bad you haven't been able to find someone to fully test the system and diagnose the issue.
    The tech did also adjust the blower speed so the coil won't get too warm. The blower speed was a bit too low.
  2. #93
    Oct 2010
    Quote Originally Posted by 545GAlady View Post
    The issue is probably undersized ductwork not blower speed.
  3. #94
    Sep 2012
    Does 8 inch ductwork sound to small for a 4 ton blower? There's a 12 inch trunk that comes off the supply plenum.
  4. #95
    Dec 2010
    Quote Originally Posted by jtrammel View Post
    You need to go back to the pictures of these systems. I used to say I've seen it all, but I live in the midwest, it takes longer for the crappy workmanship to get here.
  5. #96
    Sep 2012
    We never have a problem with air coming out of the vents. The unit was overcharged when it was installed. We always feel comfortable on our first floor and the unit does great in both heating and cooling. Our furnace has never failed once. Same with the blower motor.
  6. #97
    Rochester NY
    Eek! Pics?
  7. #98
    Oct 2010
    Quote Originally Posted by George2 View Post
    I can't look at attachments on my phone for some reason and I rarely get on htalk on my computer. So I'll take your word its pretty bad.
  8. #99
    Dec 2010
    The first floor basically has no load. You have a HVAC system on every floor. You could almost leave the 1st floor system off and be comfortable from the systems above and below.
    I said the workmanship was terrible, I would need to go back and read about the supplies and returns on that system.
    It is true and very frustrationing that equipment is so forgiving because the people that do that kind of work get away with murder.
  9. #100
    Dec 2010
    Quote Originally Posted by tedkidd View Post
    Eek! Pics?
    Picture are on page 4, number 59 and also on page 6, numbers 26 and 24.
    Caution: Not for the weak at heart!
  10. #101
    Madison, WI/Cape Coral, FL
    We had our basement system inspected and tuned-up last Tuesday. The system is a 2003 Trane XR11 1.5 ton heat pump that heats and cool
    My question is, is he right that a return will not be needed? Are the current 2 returns enough for the system?
    Thanks in advanced.
    This is a well developed basement, do you have a dehumidifier in the space? What is the real temp/%RH during different times of the year? Does cool damp have any thing to with this problem?
    Regard TB
  11. #102
    Rochester NY
    It is true and very frustrating that equipment is so forgiving because the people that do that kind of work get away with murder.
    Nicely written.
  12. #103
    Dec 2010
    Nicely written.
    Thank you, I appreciate............I get lucky every now and then.
  13. #104
    Sep 2012
    The basement system does not effect the first floor a whole lot since there's a door that leads to the basement from the first floor and it is usually closed. The doors to the bedrooms upstairs are always closed and it always feels comfortable up there. During our heating tune-up back in early October the tech checked the airflow on the air vents on our first floor and upstairs system. He said the airflow is proper for both systems. This tech is a very good one who works in one of the highest rated companies in my area.
