Results 40 to 52 of 118
11-11-2012, 02:56 PM #40
- Sep 2012
- GA
- 306
11-11-2012, 02:57 PM #41
Professional Member*
- Dec 2010
- The Quad-Cities area (midwest).
- 1,758
Do you ever leave your computer? You respond faster than anyone I know.
11-11-2012, 02:58 PM #42
- Sep 2012
- GA
- 306
No. I just got on here because I've been gone for several hours. I'm not always on the computer, especially week days because I'm a substitute teacher.
11-11-2012, 03:00 PM #43
- Dec 2010
- 1,758
I'm not sure that I understand your question. Every supply will need to have a damper IF you want to control the airflow for that supply run.
I do have a supply in my house that I let blow "wild". In other words, it is never restricted and that was designed that way on purpose.
11-11-2012, 03:04 PM #44
- Sep 2012
- GA
- 306
Oh sorry. I kinda get it. So does that mean that if having the basement zoned off from the first floor system will only require very few dampers like for example 2 dampers (one for the basement, one for the first floor)? I don't know much about zoning. I'm still trying to learn about it and I'm still confused.
11-11-2012, 03:11 PM #45
- Dec 2010
- 1,758
Okay, sorry, it seems elementary to me. Here is how it goes (generally), there are exceptions, of course:
If you had 12 existing (supply) registers on the first floor and installed 8 new (suppl)registers for the basement, then you are going to have a total of 20 dampers.
Now, once the dampers are in place, you may, depending on the layout of the home, have 4 zones without adding dampers. Understand better?
11-11-2012, 03:12 PM #46
- Dec 2010
- 1,758
11-11-2012, 03:16 PM #47
- Sep 2012
- GA
- 306
11-11-2012, 03:17 PM #48
- Dec 2010
- 1,758
I need to read and then take my (beauty) nap. I'll respond to your posts a little later. Don't worry.
You are fun to "talk" to. I have always appreciated people that want to learn and are open to new ideas.
11-11-2012, 03:20 PM #49
- Sep 2012
- GA
- 306
That's fine. Right now I don't have anything else to say, but that could change.
11-11-2012, 04:22 PM #50
Not to intrude here, but have you considered how much air leakage you have at your rim joists? This is a major source of air leakage. That drop ceiling is not going to stop it either. The best first step regarding comfort & energy use in a home is to find out if your home has excessive air leakage and perhaps insulation issues, resolve those issues first, and then move on to equipment concerns.
11-11-2012, 04:27 PM #51
- Sep 2012
- GA
- 306
tipsrfine thanks. I can see how that should be checked first. We have had our insulation inspected last summer.
11-11-2012, 04:37 PM #52
Did you have your homes air leakage tested, with a blower door test?
