Results 1 to 2 of 2
Thread: ALC Module Compatibility
11-09-2012, 12:31 PM #1
- May 2008
- Corona Calif.
- 7
I have a customer with a I/O Flex module running in WebCTRL on the ARC156 port. Just like a regular ALC module. Can we add a MEX to the Xnet? Or does it have to be a I/O expansion module.
11-10-2012, 08:22 AM #2
- May 2009
- 552
We had some modules where the xnet port was removed from the board and module driver and then renamed for our use.
Check the board to see if it has the port. Check the driver and make sure it has xnet in there. If you have both I would say it should work.Scott Jalbert
Harris Integrated Solutions
Formerly Liebert (Emerson Network Power)
Expressed opinions are my own
