Results 1 to 1 of 1
    SW FL
    Question Heat Pump Operating Co$t Estimate for Replacement/ Southeast U.S.2000 S.F. Residence
    What is a reasonable operating cost savings expectation when replacing a "old" heat pump?
    ______________________________ "old" might be about 15 years
    HEAT PUMP REPLACEMENT ___ SOUTHEAST U.S. ___
    Typical Cooling Degree Days 1,500 and Heating Degree Days 2,900
    1,700 to 2,200 Square Feet ____ $0.12 per KiloWatt-Hour
    Operating Cost Comparison __ based on 3 Tons and 30,000 BTU/Hr
    ___________ BALL_PARK COST ______ ......... ___
    ________ 14 SEER versus 10 SEER
    Cooling - Standard Yearly Operating Cost: ___ $645
    Cooling - High Efficiency Yearly Operating Cost: $461
    ____________________ ____ Yearly Savings:_ $184 .. ~29%
    _________ 8.8 HSPF versus 7.7 ______ ........ ____
    Heating - Standard Yearly Operating Cost: __ $812
    Heating - High Efficiency Yearly Operating Cost:$710
    __________________________ Yearly Savings:$102 ... ~12%
    The Cooling Degree Days (CDD) and Heating Degree Days (HDD) average values
    are conveniently provided in the noted program based on the selected city.
    _ K.I.S.S. ... Keep It Simple and Sincere _
    _____ One might expect __ $286 __ Annual operating cost savings
    ____________ for an area with $0.12 /kW rate.
    __ $3,400 savings in 10 years ( 4% electric rate escalation) is notable.
    - Impact of Defrost cycles are not addressed. -
    You can perform this Quick, simplified evaluation given your situation
    at HVACOPCOST dot com
    Example attached
    Designer Dan
