Results 1 to 13 of 14
    Jan 2011
    Central, PA
    NFPA70E Arc Flash Regulation
    The company I work for recently adopted a uniform policy conforming to the NFPA70E. How many of you out there are working for a company doing the same. We have had alot of backlash, mostly about long sleeves in the summer. We are a large company who had to look out for the best interest of the employees as well as the company.
    Mar 2009
    Mid-Mo
    I'll say be prepared to sweat your gonads off in the summer. Its something we all have to live with now. Suit up when you have to, lose the sweater vest when you don't need it. If you have seen he videos or had any form of training the resistance will be minimal. Go on YouTube and search arc flash explosions and you will soon understand why your coworkers need to be smart and suit up.
    Columbus Ohio
    Been with the program for two years now.
    We have adapted to it well. A few suggestions that helped.
    Use the videos of actual events as a training tool. Nothing gets attention like a video of an actual accident happening.
    Buy the overall suits. DO NOT force employees to wear long sleeve fireproof clothing all the time, it's totally unnecessary, we put the suits on as needed. AKA: We don't need to be wearing long sleeve FP rated shirts while washing coils or changing out a heat exchanger.
    Get professionally fitted. Don't expect an employee to put on a hot, scratchy, uncomfortable suit that is too small and rides the crotch on a 100*F summer day. Get them right the first time, get everyone fitted.
    Buy a cheap washer and drier and set them up in the shop. Have the guys come in once a month (or more) and wash them properly. This will not only prolong the life of the suit by keeping it clean, it will invite guys to wear them more. No one wants to put on a stinky crusty suit.
    Buy spare face shields, they will crack, especially in cold weather.
    Buy a HARD storage case for the suits. I had a duffel bag for mine, it provided no protection for the helmet, face shield, or suit and bouncing around in the back of the truck caused rips, tears, and busted face shields. A Tupperware container solved this.
    UA LU189
    10mm, because it's better than .45acp
    Oct 2012
    La Crosse, WI
    At my company they trained us and gave us the special uniform shirts. They also gave us the rubber gloves with the leather protectors. We wear the same uniforms we had, they told us the only time we need to wear the special arc flash long sleeve shirt and big rubber gloves, is when we are exposed to live electical parts we could contact, like when you are checking for voltage with your meter. Once the unit is locked out we can just wear our regular uniform with the short sleeves.
    Columbus Ohio
    Quote Originally Posted by Mike19 View Post
    How do you test for voltage after locking and tagging a unit?
    UA LU189
    Oct 2012
    La Crosse, WI
    Quote Originally Posted by zw17 View Post
    What I meant was we wear the arc flash when the power is on, and once we lock out the unit we don't have to wear the arc flash anymore.
    Columbus Ohio
    What I meant was we wear the arc flash when the power is on, and once we lock out the unit AND CONFIRM, USING AN ELECTRICAL METER, THAT ALL ELECTRICAL SOURCES ARE DE ENERGIZED, we don't have to wear the arc flash anymore.
    I think this is what you meant to say, right?
    UA LU189
    Mar 2009
    Mid-Mo
    Also make sure you have the right rated equipment for the job you do. I do a lot of 480 volt work but the company only issued me a category 1 shirt. Have a procedure in place so you always do it in the same order, that way you don't forget. Remember all cotton shirts and draws under the other uniform.
    We have been on board now for 3 years...I think I forgot to mention that.
    Oct 2012
    La Crosse, WI
    It sounds like you guys have a lot more than they gave us. They gave us a long sleeve shirt, pants, rubber gloves with leather protectors, and a pair of safety glasses.
    Dec 2008
    Buffalo NY
    I just took the full training class about a month ago. Very valuable info.
    This is a coarse that every tech should take. I did not think anything of it till I learned the hazards and how quick you can be seriously or fatally injured. Many of us are in panels all the time and do not take the proper precautions or wear the proper safety equipment.
    To the man who always did it right. I love you dad and I will miss you to much for words.
    Stay Thirsty My Friends
    Support the Skilled Trades Don't DIY
    Nov 2007
    Mississippi
    I have FRC on right now. Hot hot hot
    Columbus Ohio
    This is what we are getting... 8cal kit.
    UA LU189
    Oct 2012
    La Crosse, WI
    I see, thats a bit more than they gave us, thanks for the picture.
