    Jun 2011
    Checking leaky duct system advice
    I had a Trane system installed one year ago. The duct work is 20 years old and is fiber box trunks and foil flex from the trunk to the vents. There are three returns, one 10X20 and two 20X20. Only one is high in a room near a ceiling. It is a new return added with a big flex tube to the fiber trunk under the house going back to the system.
    I have noticed a lot of dust since the new system was installed and I crawled around under the house checking for leaking seams and peeling tape. Still dusty.
    I have asked the installer for help and he suggested using a new-to-him computerized gadget that requires sealing all the vents and the returns and measuring the cfm. Then is something doesn't compute as normal, he uses theatrical smoke to infuse the system and check for leaks under the house.
    I guess this would help identify if there are leaks allowing dust from under the house ( ground that is mostly covered in plastic sheets).
    Maybe this dust is normal and not unhealthy for a house that is more than 100 years old. I just don't know.
    Any advice would be appreciated.
    Aug 2012
    What kind of filtration are you using???
    If not high effecient filter then time to upgrade.
    If so then maybe drier lint or infiltration somewhere in the return side of furnace.
    If it's fiberboard duct your talking about, then it's probably the ductwork itself that's chaffing on the inside
    Jun 2011
    That's what I was thinking. Will the test the installer/tech is planning to do a viable test? I don't have money to waste but I do want my system as clean and as effective as possible.
    Concerning the thought about the fiber ductwork, I suppose I could have the main trunks replaced with modern ductwork and step by step eliminate the old stuff over time. Seems like the flex duct wouldn't cause dust from what I can see inside the duct itself at the vent.
    Thanks for any input.
