Results 1 to 9 of 9
Thread: Goodman condensers leaking?
11-07-2012, 07:44 PM #1
Do Goodman condensing units seem to leak more often than others? The copper runs seem to be awfully small compared to a Trane, Rheem, York, etc... of the same tonnage. Anybody else out there find that these seem to fail under warranty more often than other equipment? Are they worth selling if this is the case?
11-07-2012, 08:07 PM #2
I have run into the same thing with Goodman condensing units, especially older models. They will leak right in the coil itself and most of the time they are down low in the coil. I used to take a pair of needle nose pliers and rip out the aluminum fins surrounding the copper and repair the leak. Most of the time it is a thin hairline crack in the tubing. I don't repair them anymore I just replace the coil. But yeah they are junk.
11-07-2012, 08:36 PM #3
not my favorite brand..... I like the furnaces ..... the condensing units...... not so much
11-07-2012, 08:45 PM #4
I changed a Goodman condenser under warranty last month.
Sent from my ERIS using Tapatalk 2
11-07-2012, 08:54 PM #5
Professional Member*
- May 2000
- Urbandale IA. USA
- 4,556
I have repaired several OTHER brands with the same problem.
Usually an older unit though.
.Those who dance, appear insane to those who do not hear the music.
Those who believe, appear ignorant to those who do not know God.
11-08-2012, 07:02 PM #6
Changed dozens of trane spiney fin coils. Many heil at the tube sheet. I have personally seen very few goodman coil leaks. I suppose climate plays some part in this.
11-08-2012, 11:49 PM #7
11-09-2012, 01:27 AM #8
- Aug 2012
- NE wisconsin
- 189
This summer I've found about six goodmans leaking from the evaporator, in all I think we replaced about 2 or 3 dozen evaporators this summer all 4-6 years old. But we service a lot of Goodman equipment and they aren't the only one we found with leaks from 410A and formic corrosion, and the new ones we installed were the all aluminum ones do hopefully they hold up better.
Last edited by philjafo; 11-09-2012 at 01:34 AM. Reason: forgot to finish my thought
11-10-2012, 06:30 PM #9
- Jun 2008
- Baltimore, MD
- 15
