Results 1 to 9 of 9
    Feb 2012
    Louisiana
    Goodman condensers leaking?
    Do Goodman condensing units seem to leak more often than others? The copper runs seem to be awfully small compared to a Trane, Rheem, York, etc... of the same tonnage. Anybody else out there find that these seem to fail under warranty more often than other equipment? Are they worth selling if this is the case?
    Jul 2010
    Eastern Kentucky
    I have run into the same thing with Goodman condensing units, especially older models. They will leak right in the coil itself and most of the time they are down low in the coil. I used to take a pair of needle nose pliers and rip out the aluminum fins surrounding the copper and repair the leak. Most of the time it is a thin hairline crack in the tubing. I don't repair them anymore I just replace the coil. But yeah they are junk.
    Apr 2012
    winnipeg
    not my favorite brand..... I like the furnaces ..... the condensing units...... not so much
    Jun 2009
    Upstate SC
    I changed a Goodman condenser under warranty last month.
    Sent from my ERIS using Tapatalk 2
    Urbandale IA. USA
    I have repaired several OTHER brands with the same problem.
    Usually an older unit though.
    Those who dance, appear insane to those who do not hear the music.
    Those who believe, appear ignorant to those who do not know God.
    Aug 2001
    Pavilion, NY
    Changed dozens of trane spiney fin coils. Many heil at the tube sheet. I have personally seen very few goodman coil leaks. I suppose climate plays some part in this.
    Apr 2012
    winnipeg
    Quote Originally Posted by kangaroogod View Post
    I would imagine it could......Goodman is o.k. but not my personal choice
    NE wisconsin
    This summer I've found about six goodmans leaking from the evaporator, in all I think we replaced about 2 or 3 dozen evaporators this summer all 4-6 years old. But we service a lot of Goodman equipment and they aren't the only one we found with leaks from 410A and formic corrosion, and the new ones we installed were the all aluminum ones do hopefully they hold up better.
    Last edited by philjafo; 11-09-2012 at 01:34 AM. Reason: forgot to finish my thought
    Jun 2008
    Baltimore, MD
    Quote Originally Posted by philjafo View Post
    We did a large apartment building this year with nothing but Goodman, 180 units or so. We had around 16 leaking coils right out of the box. Coils and hot surface ignitors were a big issue.
    I never want to see another Goodman again.
