Results 14 to 26 of 28
    Jun 2002
    south jersey
    Ah Jimmeyed, that metal is shiny. Very nice as usual.
    Oct 2012
    nice
    Apr 2012
    awesome work man! after seeing some of your pics i bought some tubing benders. i always brazed fittings but really like the bent look. still trying to get the hang of em! I sure miss working in a custom metal shop though. Your jobs look nice
    Nov 2012
    Very impressive. And you're right, it will probably never be that clean again. But that's Ok, that's more job security on your part when you have to go back and repair a part that was damaged because the owner didn't keep things clean and dust free.
    Jan 2011
    They primered the house after drywall. A little dust on it is all. Still pretty clean.
    Jul 2000
    Northern Wisconsin
    Very nice! Just a thought for the next time, cover it up with some plastic sheeting and painters tape until the painting is done. I've done that in the past and then I write on the tape that it's ok for the painter or general to take it off when he's done.
    Berea. Ky
    Love the your sheet metal and copper true craftsmen. When you do down flow fan coils make do make a supply drop separate or all piece because angle to the fan coil box to floor. Really looks great.
    Not in Iran
    looks like a down flowsetup
    good job
    no signature blast'em man blast'em
    !!!KILL THE TERRORIST!!!
    Nov 2012
    Dublin, CA
    Quote Originally Posted by firecontrol View Post
    Yup this is what I do too.
    Beautiful install.
    Jan 2011
    Quote Originally Posted by barneyhvac View Post
    Not sure what your saying? I have a plenum in the floor, inch smaller both ways than the outside dimensions of the fan coil. 1" folded out on the floor. When I came back, I measured it up, made the base, 24 ga, to cover the plenum on the bottom, then to fit the fan coil at the top of the transition. Outlet on the fan coil is only 11 deep, I made this one 18" deep. It tapers back. Usually try and get it off the floor at least 6". This one was taller because my filter sticks out a few inches past the fan coil, I wanted it up high enough someone wouldn't rack their cranium.
    Jan 2011
    I always lay everything out with sketch up. Just a few basic measurements is all i need.
    Berea. Ky
    Thanks got it do you have a comp program. Good quailty work great to see.
    The very humid south
    great looking work. One question, where do you get those bags for the service manuals?
