Results 1 to 13 of 28
    Jan 2011
    Won't ever be this clean again.
    New evolution zone system I put in. 3 ton 19 seer, 005 fan coil, 15kw heat, 2 zones, oversize dampers, 5" filter...
    I hate putting equipment in before they paint!!!
    Feb 2012
    Toronto Canada
    The supply goes into the ground?
    Nice clean install
    Atleast the drywall is done no dust from that
    Tallahassee, FL
    As usual perfection!
    Do you have reversing attachment for those benders?
    Jan 2011
    Supply goes into the crawl. As does return. No attic to work with. To do it over I would have put it in a closet centered in the house. Yeah I have a reverse bender attachment. I made all those bends in the garage, then shoved it outside and made my bend down the wall. No pics of the outside, It doesn't look bad just sits out too far from the house for my liking.
    Jul 2009
    Columbia, MD
    Looks Damn good Sir!.
    Dec 2008
    Buffalo NY
    Very nice metal work and install.
    Join http://scopeny.org/ Shooter’s Committee on Political Education
    The world is full of sheep,try not to join the flock.
    Support the Skilled Trades, Don't DIY
    Tallahassee, FL
    That's beautiful metal work sir. Can I admit that you inspire me to strive for perfection and have every detail as thought out as you do.
    Only I have to use more off the shelf items.
    Jan 2011
    Thanks, it helps having access to a custom duct shop. Can pretty much make anything that will fit on a sheet of metal.
    Bunch of custom stuff in the crawl. Actually a ton of ductwork in the crawl. I spent 3 1/2 days down there by myself hanging it all. Two 8x24 trunks and a 8x20. All metal. No flex or ductboard in this job.
    Quote Originally Posted by SBKold View Post
    I keep a ton of miscellaneous fasteners, clamps, straps, ect, on the truck. If you have the right piece for what your doing it makes it look that much better.
    Tallahassee, FL
    Kinda like that large pvc reducer the drain fits in.
    Do you use mastic in careful caulk gun on all the seams?
    Jan 2011
    Mastic in the crawl. Most every joint you see here, base to floor, fancoil to base, transition to fan coil, filter to transition, filter to duct has foam tape on it to seal it. A good slip and drive joint doesn't really leak much. Ill sometimes silicone the corners of some pieces if there are holes with some silver silicone. Got 1/8x1/2, 1/8x1 and 3/4x1 foam tape on the truck. Nice stuff, use alot of it.
    The 1 1/2" to 3" reducer was left by the plumber,
    Nice!
    Dec 2011
    missouri
    Very nice work!! As a service tech, I appreciate seeing all the manuals left where they will do the next guy some good. We started installing a metal file box for all paperwork on the drop of our installs, seems like manuals tend to
    " walk-off " when left laying around. H/O always puts them somewhere, then forgets where!! Again, very nice work.
    Sep 2012
    NW Louisiana
    Sweet install. Your sheet metal pictures always impress me.
    CT
