Results 1 to 13 of 16
11-06-2012, 06:53 PM #1
- Oct 2012
- 26
how to quantify in dollars the differences in efficiency numbers?
I have 2 options:
option 1: SEER 15, EER 12.5, HSPF 8.5
option 2: SEER 16.2, EER 13.5, HSPF 9.0
is there anyway to translate the efficiency into dollars? does anyone have a ballpark figure?
thank you!
11-06-2012, 09:10 PM #2
- Jun 2001
- Moore, Oklahoma
- 2,596
How may dollars do you spend in a year for heat/cooling?
In most cases it makes more sense to use the extra $$$ to seal up the house instead of buying a higher end HVAC unit.
11-06-2012, 09:25 PM #3
You can put numbers on the difference; however, "there are far too many other factors that hinder or contribute to those efficiency numbers that their small rating differences become insignificant."
There are countless ways that the efficiency of heating & cooling a home can be improved whereby the small difference in equipment rating numbers can become relatively irrelevant.
You have far more than two options that can affect the cooling & heating annual utility costs...it might pay you to explore them...AOP Forum Rules:
Rules for Posting
Rules For Equipment Owners
Equipment Owners Find a Contractor HERE!
udarrell
11-06-2012, 09:27 PM #4
- Oct 2012
- 26
Generally, I agree with your comment though the price difference is low after all rebates/discounts are applied. That's the reason why the question is purely about efficiency because the cost is not a significant difference but just enough to ask my question...
Thank you.
11-06-2012, 09:30 PM #5
- Oct 2012
- 26
11-06-2012, 09:54 PM #6
- Jun 2001
- Moore, Oklahoma
- 2,596
If one is a 2stage and the other is a single stage there may be comfort differences.
11-06-2012, 10:37 PM #7
not likely
11-07-2012, 02:30 AM #8
Professional Member*
- Nov 2004
- SW FL
- 5,275
Designer Dan
It's Not Rocket Science, But It is SCIENCE with "Some Art".
11-07-2012, 08:14 AM #9
- Oct 2012
- 26
Thank you!
11-08-2012, 12:42 PM #10
- Oct 2011
- NJ
- 97
A life cycle cost comparison can help you estimate how much will ultimately be POTENTIALLY saved over the life of the equipment (potentially because it is an estimate, depending on variables that might change in real time). In order to figure this, you need the capacity of the units, the full cost including installation, the annual and occasional maintenance fees, your local energy rates and your location's average heating and cooling degree days.
Quick estimates of savings can be determined just by using the capacity of the equipment, EER, a set amount of hours and local electrical rates.
For instance, 18 ton units with different EER running 1000 hrs (that's 18,000,000 btuh):
1.5 ton 13.0 EER unit running 1000 hrs at $.155kWh will cost $215.18
1.5 ton 15.5 EER unit running 1000 hrs at $.155kWh will cost $179.71
1.5 ton 20.0 EER unit running 1000 hrs at $.155kWh will cost $139.78
Your example using the same size units at 1000 hrs:
1.5 tons 12.5 EER unit running 1000 hrs at .155kWh will cost $224
1.5 tons 13.5 EER unit running 1000 hrs at .155kWh will cost $207
A little more than 7% savings in this example, YMMV.
Keep in mind this example is for a 1.5 ton unit running 1000 hrs.
11-08-2012, 01:54 PM #11
- Oct 2012
- 26
11-08-2012, 02:35 PM #12
- Oct 2011
- NJ
- 97
Your best justification is probably just the fact that the more efficient model is the more environmentally favorable choice.
Also look into incentives for choosing the higher efficiency model, not sure if there are any right now. It varies by location, sometimes your utility company may even offer something.
11-08-2012, 04:47 PM #13
- Jun 2001
- Moore, Oklahoma
- 2,596
Good luck finding any air cooled equipment over 14 EER w/o breaking the bank. 12 EER equipment is common and affordable, just one line higher than the builder grade in most brands.
