Results 1 to 13 of 18
Thread: How to twin furnaces
11-06-2012, 02:26 PM #1
Sent from my HTC VLE_U using Tapatalk 2
11-06-2012, 02:37 PM #2
Scary!
11-06-2012, 06:41 PM #3
Professional Member*
- Jun 2011
- Muncie, Indiana
- 218
How did this hack get a hold of trane equipment
The only true knowledge is the pursuit of knowledge
11-06-2012, 07:02 PM #4
- Jan 2011
- 502
Trane will sell to about anyone it seems. I see plenty of hacked in trane stuff.
11-06-2012, 10:13 PM #5
Are those going into masonry chimney? Flues look rusted out.
11-06-2012, 10:18 PM #6
- Jul 2007
- Chicagoland
- 468
Ive only seen a few twin systems. Is it only the return that is done wrong or am I missing something?
11-06-2012, 10:29 PM #7
the thing looks like a complete disaster
11-07-2012, 12:58 AM #8
160,000 btu w 3 ton of airflow? Wonder what esp was on THAT!
Short cycling, hitting limit, and/or wet basement?Which makes more sense to you?
11-07-2012, 06:17 AM #9
3 furnaces run a combined horizontal flue to a chimney. 3.5 ton drives, 100K furnaces 7.5 ton Trane A/C on some ancient coil above both furnaces. Return air comes in the right furnace. 1 small filter. The Tranes are so rusty from the A/C constantly freezing up. Little damp basement room where they store pool chemicals. The techs condemned a 24 year old Ruud 60% that sits to the left of the twins. Cracked, impressive it lasted that long.
11-07-2012, 06:32 AM #10
Are you guys replacing all 3 and fixing everything or just replacing what is inoperable.
11-07-2012, 08:03 AM #11
The energy bills will be your friend here if you need help. You should be able to save 50% even before looking at problems with the building enclosure.
11-07-2012, 06:15 PM #12
- Jun 2011
- Muncie, Indiana
- 218
11-08-2012, 06:19 AM #13
At the moment, probably just changing the split open Ruud not in the picture. The Tranes are so rusty, won't be long for them. I think a lot is from coil leaks and freezeups. Both outdoor units are on old coils. The 20 year old Bryant A/C on the single furnace has the original early 70s evap. We'll see if we have any luck getting them to change the A/C. But it never causes any trouble.
